How Is This Subpanel Ground? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2008, 10:24 AM   #16
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
It looks like a blue, a red, and a white enter the panel from the BX. With the blue used for the grounded conductor, I wonder what the white does? I'm not familiar with this panel and my eyes are getting old, are the other breakers tandems or single pole? I noticed three on the top row.
John
jrclen is offline   Reply With Quote
Old 07-16-2008, 11:12 AM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hi John
The breakers you are referring to are GE THQP's. They are single pole half size breakers. GE's answer for a tandem breaker. If you look at the exposed bus stabs you will notice little tabs on the side of the stab. There are two on each side. This allows two 1/2" thqp's to be installed on each stab filling a full size 1" space. GE's THQL breaker is a full size breaker and it will also fit this panel. Alternately a double pole handle tied thqp ( 2 thqp's factory tied ) can be used in this panel but you must insert it between stabs so that it catches a tab on different legs.
The white wire appears to be a grounded leg.
Old 07-16-2008, 07:41 PM   #18
jrclen's Avatar
Rewards Points: 514
Originally Posted by Stubbie View Post
Hi John
Thanks Stubbie. So the grey breakers are full size AFCI? I have no experience with AFCI's yet as they are not required here. Are they connected like a GFCI? I can't figure out the wiring. If the blue is the grounded conductor, wouldn't the additional white grounded conductor cause problems? I'd like to see the connections on a receptacle if the OP is still around.
John
Old 07-16-2008, 08:03 PM   #19
Electrician
Yes, the gray breakers are AFCI's. and they get wired just like GFCI's... I figured out what they did too, they used 4 conductor cable, they used blk, and white for one circuit, and blue and red for a AFCI circuit... pretty smart but illegal...
chris75 is offline   Reply With Quote
Old 07-17-2008, 09:31 AM   #20
jrclen's Avatar
Rewards Points: 514
Ok, that I can at least understand. Thanks.
John
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
subpanel ground rtyui2 Electrical 5 12-08-2007 06:17 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
