How Is This Subpanel Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2008, 01:34 PM   #1
How is this subpanel grounded?
Hey,
I recently moved into this house and am looking to install some outlets upstairs. Previously, a sub panel was installed which should make this job a lot easier, but I can't seem to figure out how it is grounded. The two neutral/ground buses are attached with a tie bar which I originally thought had to be separated (and then one bus used as a neutral and the other as a ground). Is this subpanel installed properly? If so, how is it grounded?
It also appears that there are only 3 wires coming into the subpanel, 2 hot and a neutral... Is that up to code?
hopefully this picture uploaded properly.
FixingOlga is offline   Reply With Quote
Old 07-15-2008, 02:56 PM   #2
joed's Avatar
Rewards Points: 11,530
If the sub panel is connected to the main panel via conduit that would be the ground. The ground and neutral should be kept separate. i can't tell if the bond screw is inplace not connecting the neutral bus to the box.
I don't see any ground wires in that picture. All I see is blue,red, black and white wires. Ground must be green or bare.
It appears as if this house is wired using conduit. If that is true then the conduit is the ground.
Old 07-15-2008, 03:45 PM   #3
Power Gen/RS Engineer
Rewards Points: 566
Look closely at the left side of the tub. There are definitely box connectors visible for conduit. As Joe says, the metallic raceway system (assuming that it is continuous) serves as the ground and is perfectly acceptable according to the NEC. In fact, the raceways serve as EGC's for each of your branch circuits as well. Therein, you will not typically have any ground wires like you would if this was wired with NM cable (one exception would be if you had a piece of greenfield/FMC connecting to the tub. Then you would have at least one ground wire).
Looking more closely, your neutral terminates on the top lug and you can trace across the top bus and down to the bottom bus via the splice plate. Both busses are connected and are therein both acting as neutral busses.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-15-2008, 05:42 PM   #4
Electrician
call me crazy but did they use BLUE as a grounded conductor?
chris75 is offline   Reply With Quote
Old 07-15-2008, 06:30 PM   #5
joed's Avatar
The blue is connected to a breaker. It is a hot wire. Conduit makes it easy to use different colours for different circuit. Makes for much easier circuit tracing.
Old 07-15-2008, 06:33 PM   #6
Electrician
You wanna look at that again and tell me what you see... Let me give you a BIG hint, thats a AFCI breaker....
Old 07-15-2008, 06:35 PM   #7
joed's Avatar
I still see a blue and a red wire attached to a possible double pole GFCI breaker.
Old 07-15-2008, 06:37 PM   #8
Electrician
Guess you never wired one before, never mind. Just for fun, you wanna explain to me how its getting its 2nd pole?
Old 07-15-2008, 06:40 PM   #9
Electrician
Couple questions, what country is the OP from and is that Panel really mounted horizontally?
Old 07-15-2008, 06:55 PM   #10
joed's Avatar
I'm getting in a pissing match. I'll just say you must be right. I never wired one before.
Old 07-15-2008, 06:57 PM   #11
Electrician
I wasnt trying to have a peeing match with you, I was only pointing out a violation to use a blue wire for a grounded conductor here in the US...
Old 07-15-2008, 07:06 PM   #12
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Honestly, I think you both were talking about 2 different breakers. the one on the right is blue and re-indentified white, the one on the left is blue.
wirenut1110 is offline   Reply With Quote
Old 07-15-2008, 07:20 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I pretty darn sure Chris is correct on this. Both the breakers in question are single pole AFCI. That panel is a GE, the positions they are installed in will only allow connection to one leg. So the blue is used as a grounded conductor from the position it is installed on the afci. My guess they wanted to reidentify the blue as white like the other afci was done.
Last edited by Stubbie; 07-15-2008 at 07:21 PM. Reason: realized an error in first reply
Old 07-15-2008, 08:40 PM   #14
jbfan's Avatar
Rewards Points: 138
Looks like a blue wire with white tape maybe connected to the netural connection on an arc-fault.
Old 07-16-2008, 09:23 AM   #15
The picture loaded sideways, but the subpanel is installed upright. Thanks for all the input. I'm in new york city, and we can only use BX wires here because the rats eat through nm. So they, and the conduits, must be acting as the ground.
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
subpanel ground rtyui2 Electrical 5 12-08-2007 06:17 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
