How To Seal A Wall Penetration - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 05:27 PM   #1
Rewards Points: 348
How to seal a wall penetration
I need some advice on how to seal around a 1.25" conduit coming through a poured concrete wall.
The conduit is below grade about 6" and has been leaking around it, not through it. It was sealed with pure silicone, but that apparently has not worked completely.
Any suggestions will be greatly appreciated.
Thanks.
herdfan is offline   Reply With Quote
Old 05-21-2013, 05:36 PM   #2
Rewards Points: 13,458
Now all the silicone has to go.
Use hydrolic cement.
herdfan (05-22-2013)
Old 05-22-2013, 06:02 AM   #3
Rewards Points: 348
Thank you. I looked it up and that looks perfect.
Old 05-22-2013, 06:05 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Linkseals are the king for new installations, but hydraulic cement is your next best solution...
Old 05-22-2013, 06:06 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why anyone comes in below grade is beyond me.
Old 05-22-2013, 06:13 AM   #6
E2 Electrician
Aesthetics, Lb's look like **** on the outside of a building.
Old 05-22-2013, 06:55 AM   #7
k_buz's Avatar
LB vs leaks in a basement wall...I'll take the LB every time.
Old 05-22-2013, 07:13 AM   #8
E2 Electrician
It's all in the installation, I've personally never had an issue.
Old 05-24-2013, 04:55 PM   #9
Rewards Points: 348
The hydraulic cement worked great. Thank you!
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Safe to seal exposed cinder block wall in basement? cne24 Concrete, Stone & Masonry 4 09-20-2012 07:43 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
