How To Seal Conduit Body Going Into The House? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2014, 06:21 PM   #1
Rewards Points: 1,225
How to seal conduit body going into the house?
I'm wiring an outdoor shed for power and coming out of the house through the wall that holds the breaker panel with a 1.5 inch LB conduit body. My question is, what is the typical mechanism for sealing/attaching the conduit body to the house? I can use a strap to attach the conduit which will also hold the conduit body but still not sure how to seal it. Should I just use some good calk or silicone sealant?
dalepres is offline   Reply With Quote
Old 05-31-2014, 07:16 PM   #2
Rewards Points: 436
Good caulk or silicone sealant it would be. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
dalepres (05-31-2014)
Old 05-31-2014, 09:27 PM   #3
Rewards Points: 774
I assume you mean around the conduit? Silicon, inside the conduit for stopping air flow, and possible condensation, duct seal.
Know A Little is offline   Reply With Quote
Old 06-01-2014, 09:43 AM   #4
I hadn't thought about inside the conduit. Thanks for mentioning it.
Old 06-01-2014, 11:40 AM   #5
Rewards Points: 3,764
I wouldn't use caulk inside the conduit. It's not too fun taking it out during repairs/alterations. A wad of pink fiberglass will do fine.
Bob Sanders is offline   Reply With Quote
Old 06-01-2014, 03:49 PM   #6
Rewards Points: 774
Caulk was not recommended for in the conduit duxseal (above I posted DUCT SEAL), the electricians cover all
http://www.manvillerubber.com/pdf/DuxSeal.pdf
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Extra wire in conduit body allowable? WillK Electrical 10 06-06-2011 11:53 AM
Running a new line for stove in conduit on outside of house nocsec Electrical 14 12-31-2010 08:52 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
