How To Safely Replace A Space Heater Cord? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 03:14 PM   #1
Rewards Points: 33
How to safely replace a space heater cord?
I have an old heater that still works, but the cord has worn down from the strain relief. I'd like to replace it with a new cord, but I can't find one rated for use with a heater. It uses a grounded type cord.
Sliding Man is offline   Reply With Quote
Old 12-29-2009, 08:49 PM   #2
Rewards Points: 1,448
Some things you can do:
1. Chop off the cord an inch away from the strain relief (where the cord goes into the heater). Open up the heater to see how the cord was wired. Cut away the jacket on the cord to expose enough of the conductors to reconnect to the inside of the heater.
2. Get a 14 gauge 3 wire extension cord. Cut off the receptacle unit at the end. (You might leave a foot of cord still attached to the receptacle unit so you can re-use that in the future.) Cut away the jacket of the cord to expose enough of the conductors to connect to the inside of the heater.
AllanJ is online now   Reply With Quote
Old 12-29-2009, 10:24 PM   #3
I would suggest trying an appliance parts store to see if they have the proper type of heater cord. Heating appliances use a special type of cord (type HPN) and an ordinary extension cord isn't really suitable as a replacement.
Matsukaze is offline   Reply With Quote
Old 01-03-2010, 06:14 PM   #4
Rewards Points: 33
Thanks.
Old 01-04-2010, 12:24 PM   #5
Rewards Points: 82
Never modify any appliance cords in any way. There is a new cord ready for you to install in your heater at most any hardware, appliance or big box store. Whenever I decommission any appliances, I keep the cord. I have a great selection of appliance cords in stock here at home at all times.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Space Heater And K-1 Kerosene bobo General DIY Discussions 7 10-25-2006 11:38 PM
