How To Run Wires Through An Attic? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 10:13 AM   #1
How to run wires through an attic?
I'm running some 12-2 from one side of my garage through the attic to the opposite wall in order to add some outlets. Do I need to run the wires through the cieling joists (drilling hole in each one), or run the wires over the top of them?
mopowers is offline   Reply With Quote
Old 02-27-2010, 10:28 AM   #2
Rewards Points: 506
Assuming it is unfinished attic, just go over the top.
jlmran is offline   Reply With Quote
Old 02-27-2010, 10:40 AM   #3
Licensed electrician
Rewards Points: 1,494
If you have trusses you do not want to drill them.
Old 02-27-2010, 12:12 PM   #4
Yes they are trusses and the attic is not finished nor will it be.
I will just lay the wires over the top. Thanks for the help!
Old 02-27-2010, 12:31 PM   #5
There is more to it than just laying the cables on top the trusses. They must be properly secured and also follow this Article.
320.23 In Accessible Attics.
Type AC cables in accessible
attics or roof spaces shall be installed as speci
fied in
320.23(A) and (B).
(A) Where Run Across the Top of Floor Joists.
Where
run across the top of
floor joists, or within 2.1 m (7 ft) of
fl
oor or floor joists across the face of rafters or studding, in
attics and roof spaces that are accessible, the cable shall be
protected by substantial guard strips that are at least as high
as the cable. Where this space is not accessible by permanent
stairs or ladders, protection shall only be required
within 1.8 m (6 ft) of the nearest edge of the scuttle hole or
attic entrance.
(B) Cable Installed Parallel to Framing Members.
Where the cable is installed parallel to the sides of rafters,
studs, or
floor joists, neither guard strips nor running boards
shall be required, and the installation shall also comply
with 300.4(D).
This Article applies to NM as well as Type AC cable.
Old 02-27-2010, 12:39 PM   #6
Thanks! The way I read it is that since the attic in question is not accessible by "permanent
stairs or ladders," I only have to protect the wires within 6' of the attic access hole.
Am I reading this correctly?
Old 02-27-2010, 12:41 PM   #7
Sorry for the stupid question, but does a small 3/8-1/2" hole compromise the integrity of the truss? Is it in the code?
Old 02-27-2010, 01:28 PM   #8
You are correct.
Old 02-27-2010, 03:48 PM   #9
Nothing wrong with putting them on the underside of the roof rafters is there?
Mike in Arkansas is offline   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Wiring Protection for Accessible Attic BillyDIY Electrical 6 11-05-2009 08:44 PM
Re-routing wires in attic blakstarr Electrical 10 11-24-2008 05:57 PM
Running a pipe between basement & attic Piedmont Electrical 4 06-12-2008 10:35 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
