How To Run Conduit In Finished Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 10:11 PM   #1
How to run conduit in finished wall
How do you run conduit in a wall thats already finished? Doing a kitchen remodel and conduit is code dont want to rip down plaster and lath on these walls.
Kurt1968 is offline   Reply With Quote
Old 12-21-2010, 11:42 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
flex conduit (FMC). Not sure of Chicago codes so make sure it is acceptable.
Old 12-22-2010, 01:04 AM   #3
" Euro " electrician
frenchelectrican's Avatar
FMC and the distance will depending on the local code requirement so check with them first before you do anything.
I am sure one of the members in here are from Chicago so they will know more details.
Merci.
Marc
Old 09-14-2011, 09:09 PM   #4
Flex conduit in Chicago
The whole point of flex conduit is that it can be threaded without opening up the wall. Apparently that is permissible in Chicago - when the wall has no better option, there is not a length restriction on how much you can thread into the wall.
FWCasual is offline   Reply With Quote
Old 09-14-2011, 09:13 PM   #5
Putting conduit in walls ahead of time - chicago
I'm looking at an old house in Chicago, and might want to blow in insulation. I know Chicago does not let people do their own wiring ... put can I put my own conduit in? I normally would not bother, but it makes sens to put some flex conduit in before blowing the insulation in. It would have to wiring in it, but would be at the ready for future outlets I might want to put in. I would only feed the part into the walls - the rest, the electrician could do later. PS I would not have flex conduit sticking out every six feet - I would put an attractive full plate on the outlet until future use - a "dead" plate. I've seen this in Chicago condos, where apparently a smart person put conduit in for future tenant/owner use.
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 06:22 PM
Finished Retaining Wall wombosi Landscaping & Lawn Care 9 11-15-2009 04:10 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
