How To Run 4-6 Small Computer Fans Off Of One Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2008, 11:06 AM   #1
TylerPlumb's Avatar
Post
How to run 4-6 small computer fans off of one switch?
Hi everyone,
Let me start off by saying I am brand new to these forums - joined today! Hopefully I can find some help here
I have a small project going, and I would like to run four (maybe six in the future) small computer fans off of a light switch. First and foremost, is this possible?
If it is, how would I do it? I'm a plumber with very little experience in electrical; I know how to splice and positive and negative, but that's about it!
Also keep in mind that computer fans probably don't require that much voltage, so will I also need some sort of converter?
Thanks so much!
--Tyler
TylerPlumb is offline   Reply With Quote
Old 05-08-2008, 01:22 PM   #2
Not a converter, you'll need a transformer.
The transformer must match the voltage of of the fans, and be rated (va) to handle the up to 6 fans you are going to have.
And please remember to wash your hands before you touch the fans, transformer, or switch.
Joba Fett is offline   Reply With Quote
Old 05-08-2008, 01:58 PM   #3
Underground Techie
sevver's Avatar
I would say that you could use an old computer power supply, and simply plug it into a switched outlet. You could connect the fans up to that pretty easily. One of the fans I can see laying around here runs on 12 volt DC.
sevver is offline   Reply With Quote
Old 05-08-2008, 03:11 PM   #4
joed's Avatar
Rewards Points: 11,964
Well it depends on if you are refering to 12 volt DC PC fan or 120 volt AC muffin fans like larger computer equipment uses. Some of them are even 240 volt.
If they are 12 volt then get yourself a 12 volt power supply or battery charger and plug it into a switched receptacle.
Old 05-09-2008, 07:39 PM   #5
TylerPlumb's Avatar
Hey, thanks for the responses all!
This is what I'm using:
http://www.newegg.com/Product/Produc...82E16835200002
Each one reads "DC 12V 0.14A" I am guessing that is 12 volts, 0.14 amps??
Old 05-09-2008, 10:30 PM   #6
joed's Avatar
12volt DC fans. Use an old PC power supply or a battery charger to power them.
Old 05-09-2008, 11:15 PM   #7
Idiot Emeritus
Rewards Points: 1,492
The power supply you'll need must be 12 volts DC, and for 6 fans, at least 0.84 amps. It can be more than 0.84 amps, not less. There are a multitude of plug-in types that are 12 volt DC and 1 amp. Any of these will work.
If there is a plug on the cord, just snip it off, and strip the wires back some. The fans will be wired in parallel, meaning that one wire from each fan will tie to one wire from the power supply. The other wires from each fan tie to the other wire from the power supply. If you have 6 fans, you'll have 2 splices each containing 7 wires.
You're a plumber, one wire of the power supply is the cold water supply, and the other wire is the hot water supply. You're connecting 6 sinks (fans). Wire the fans the same way.
Rob
micromind is offline   Reply With Quote
Old 05-09-2008, 11:55 PM   #8
TylerPlumb's Avatar
Thanks for the posts fellas, going to make my weekend trip to Home Depot. Will report back with results soon...
Tyler
Tags
computer fan , electrical , fans
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
