How To Rough In 2 Rooms On One Circuit - Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 07:50 PM   #1
Rewards Points: 640
How to rough in 2 rooms on one circuit - lighting
I have a 20-amp circuit that is going to two bedrooms for lighting... right now it comes into one room into the switch box (plastic 20.5 cu in) then a line from that runs to a set of 4 75watt recessed lights.. that is it... this new room needs to be fed from that switch box, but that would put probably too many wires in that box?
20.5 cu inch box with 3 12/2 lines seems overcrowed.. think the max is 9 12 gauge wires?
how would you route something like this? or should a 2 gang box with a mud ring be used? or just a smarter routing method? thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 11-08-2012, 08:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
3 x12/2 is 6
1ground
plus 2 for the switch
total 9
X 2.25
equals
20.25
Your box is OK.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
BlueBSH (11-08-2012)
Old 11-08-2012, 08:13 PM   #3
Rewards Points: 640
Originally Posted by rjniles View Post
3 x12/2 is 6
1ground
total 9
X 2.25
equals
20.25
Your box is OK.
oh? we don't count the ground wire for each run?
Old 11-08-2012, 08:15 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
All ground wires count as one.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Old 11-08-2012, 08:15 PM   #5
A "Handy Husband"
rjniles's Avatar
All grounds count as 1.
Old 11-08-2012, 08:16 PM   #6
Rewards Points: 640
ah ok, that's what confused me with the box sizing then, I was counting it all
Old 11-08-2012, 08:16 PM   #7
A "Handy Husband"
rjniles's Avatar
Damn, you are fast.
Old 11-08-2012, 08:17 PM   #8
Rewards Points: 640
Saves me some time from having to replace the box at least!
Old 11-08-2012, 08:19 PM   #9
jbfan's Avatar
Rewards Points: 648
Damn, you are fast.
Only when needed!
rough in for in cabinet lighting? BlueBSH Electrical 4 06-21-2012 05:30 PM
Rough in for under cabinet lighting Lattimer Electrical 5 01-23-2012 04:32 PM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Adding outlets to existing 15A lighting circuit rstain Electrical 3 12-03-2011 10:30 AM
Recessed Lighting - How many per 20amp circuit dcd22 Electrical 10 08-27-2007 05:36 PM
