How To Replace Socket In Recessed Housing? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 01:11 PM   #1
How to Replace Socket in Recessed Housing?
I'm planning on replacing the existing Edison sockets in multiple 5" recessed cans to be GU24 sockets. The existing cans are standard cans where the socket is attached to the top of the housing (I can attach pics if required but the sockets look like any other Edison socket).
Here is a link to the GU24 sockets I am looking at:
http://www.maxlite.com/PDFs/FocusSheets/GU24Socket.pdf
1) How do I know which socket fitment I need to buy?
2) How would the GU24 socket be attached to the housing? I am not seeing in my head how the new socket would replace the existing Edison socket and how it would be secured.
Thanks in advance!
chewbakarox is offline   Reply With Quote
Old 09-30-2011, 06:14 PM   #2
Electrical Contractor
kbsparky's Avatar
Simply use the screw-in adapter (MLGSML) that is shown in the link you provided.
Those are one-way adapters, and once installed, you won't be able to change your mind and go back to using edison base bulbs.
-KB
Old 10-02-2011, 11:42 AM   #3
KB - I am holding off on the screw-in adapter as a last resort. My worry is that the adapter will add length to the bulb, causing it to hang out below the bottom of the trim.
I unscrewed the socket from the housing and took a couple pics. Any thoughts on which GU24 replacement socket would work?
How to Replace Socket in Recessed Housing?-img_0068.jpg   How to Replace Socket in Recessed Housing?-img_0072.jpg
Old 10-02-2011, 12:12 PM   #4
Code05's Avatar
Rewards Points: 1,104
Can you get that mounting tab out of the top of the can without destroying it? If so, reuse it on a replacement socket.
Code05 is offline   Reply With Quote
Old 10-03-2011, 09:56 AM   #5
Code - I'm not sure if I can get to it. I need to get up in the attic and check out the top of the housing.
If I do end up somehow modifying the mounting bracket (or creating a new bracket) to fit a different socket, will I have any issues with code compliance?
My other question is, once I do figure out how to mount it, what is the correct way to splice the wiring? Can I simply use some wire nuts within the bulb housing, or would I have to run the wires up to the j-box on top?
Old 10-03-2011, 01:06 PM   #6
Code05's Avatar
Code allows you to modify a fixture using listed parts. The site says they are.
As far as modifying a part/bracket, inspector decides if it is acceptable.
If you can not reuse that bracket, you are going to have a heck of a time getting something to fit.
All connections must be made in the J-box on the fixture and not in the bulb housing.
You realize that adapter only adds 1/2".
Old 10-03-2011, 05:22 PM   #7
Thanks...I think I will give the adapter a try and just see how it looks. Remounting the socket is sounding like a royal pain.
when to replace chimney marchaels Building & Construction 2 09-07-2011 07:36 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 04:42 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
