How To Replace Pull Chain Switch On Ceiling Fan Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 08:15 PM   #1
how to replace pull chain switch on ceiling fan lights
Is there a video that will show how to replace the pull chain switch on a ceiling fan? I have removed the "housing unit" from the fan. There is a white wire and a black wire that connects to the fan itself. On the pull chain there are 2 black wires. Not sure which wires on the "housing unit" to attach them to.
Since there are only 4 wires, 2 on the housing unit, one black one white that I know gets connected back to the fan. what wires do the 2 black wires on the pull chain connect to?
carolraine is offline   Reply With Quote
Old 07-25-2011, 06:38 AM   #2
Rewards Points: 1,548
With just two wires on the pull chain switch, you connect the new switch the same way as the old switch. It does not matter which wire is which on the switch.
It gets tricky with multi speed or multi function pull chain switches, you have to refer to the instructions for the new switch and it is possible you have to take apart the old switch to find out what wire does what.
There are enough variations of pull chain switches so it is not practical to make a generic video of how to install one.
Ceiling Fan 3 way switch puzzled MattDice Electrical 4 05-08-2011 02:33 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 08:51 PM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 07:10 AM
Pull chain switch installation rgm Electrical 1 09-05-2008 11:30 PM
