How To Replace DP Switch With A SP - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 12-06-2016, 05:06 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Re: How to replace DP switch with a SP
If you capped the wires individually in the garage, that is the problem. You have to connect the wire that was on the common to one of the travelers.
Sent from my RCT6203W46 using Tapatalk
joed and MojoinTX like this.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
MojoinTX (12-07-2016)
Old 12-06-2016, 05:09 PM   #17
joed's Avatar
Rewards Points: 13,728
You didn't follow the directions rjniles gave you about the garage switch connections.
The Following User Says Thank You to joed For This Useful Post:
Old 12-07-2016, 05:12 PM   #18
Rewards Points: 18
I finally figured it out and everything is working. There were two common cables in the garage controlling 3 lights, which was confusing me. Thank you @rjniles and @joed for your help.
MojoinTX is offline   Reply With Quote
Tags
dpst , replacing , spst
Connecting Ceiling Light/Fan. Multiple Switches. One switch box with three cables. AlpineB Electrical 7 04-12-2016 12:19 PM
replace light switch Veltorio Electrical 3 02-04-2014 08:29 AM
Trying to replace a dual single pole switch. bahaisamurai Electrical 4 09-01-2013 08:12 PM
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 05:19 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
