Old 01-19-2013, 07:25 AM   #1
How to replace the architrave switch?
I need to replace the architrave switch. I have checked online, but the switch is different to mine. Most switches online has only three wires. But my one has four. I wonder if anyone can tell me the difference between the four and how to replace it?
Much appreciated.
How to replace the architrave switch?-architrave-switch.jpg   How to replace the architrave switch?-light-switch.jpg
smoyi is offline   Reply With Quote
Old 01-19-2013, 09:14 AM   #2
Sounds like you have a three way switch instead of a two way.
Can you turn the light on from more then one place with two differant switches? That would take a three way switch.
You need to be looking someplace local for that switch, electrical supply, hardware store ECT.
Old 01-19-2013, 10:12 AM   #3
Switches with four terminals are used for lights controlled by switches in three or more locations. Also for certain kinds of equipment where both hot wires are switched as opposed to just one.
To find out for sure you would need either the switch instructions or to conduct tests by taking a multimeter and measuring continuity between every combination and permutation of terminals taken two at a time. Repeat the tests with the switch in the other position.
If the switch is defective, it will require intuition that experienced electricians have to interpret the test results. (You don't need an electrician's license to have that intution.)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 01-19-2013, 10:24 AM   #4
joed's Avatar
Is this possibly a low voltage controlled system?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-19-2013, 11:58 AM   #5
Electrical Contractor
kbsparky's Avatar
Unless there are other switches that control the same light, maybe you have a double-pole switch?
Did you check for replacement switches at Mitre10?
-KB
Old 01-19-2013, 12:51 PM   #6
Well as usual, 4-way switches are called something else in other parts of the world...
[Readers in the UK should read "two-way" for the American "three-way" and "intermediate" or "crossover" switch for the American "four-way".]...
http://en.wikipedia.org/wiki/Multiway_switching
Billy_Bob is offline   Reply With Quote
Replace Photocell with Toggle Switch AberKat1016 Electrical 1 06-21-2012 09:40 PM
3 way switch replacement in 1923 old house elcc1958 Electrical 3 02-06-2012 09:42 PM
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 06:19 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
looking to replace a rotary switch Unregistered Electrical 1 03-31-2004 01:57 PM
