How To Replace A 2 Gang Switch Box With A 3 Gang Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 01:18 PM   #1
Rewards Points: 308
How to replace a 2 gang switch box with a 3 gang box?
What would be the best way to remove the existing box?
smokey847 is offline   Reply With Quote
Old 03-16-2012, 01:28 PM   #2
Licensed electrician
Rewards Points: 1,758
Is the box nailed from the side or is there a bracket in front of the stud? Nails can be cut with a hacksaw blade inserted next to the stud.
You may find it easier to cut the larger hole and see what you are dealing with.
Old 03-16-2012, 02:13 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
You also want to make sure you can fit a 3 gang box in it's place.
Ask how I know this!!
Old 03-16-2012, 02:25 PM   #4
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Gets interesting when you remove the box and find out that there is a 2x4 or 2x6 on both sides of the box. Had that happen before. Now if there is no specialty dimmer or anything else required I just change something over to a double switch. Or a switch and outlet combination
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-16-2012, 04:40 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
That's why I always probe the side of the existing box for space before I open the wall. Don't ask me why I have learned to do that
Coastal South Carolina
Old 03-16-2012, 04:44 PM   #6
A "Handy Husband"
rjniles's Avatar
To the OP:
After you insure space for the larger box, mark and cut the wall surface. Put a pry bar between the stud and the box and open some room for a saw blade. Cut the box nails with a sawsall (best) or a hacksaw (more work and I am lazy).
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
hard to fit duplex switch and dimmer in 2 gang. please help fabian Electrical 9 01-18-2010 07:54 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Help: All I wanted to do was replace a light switch MicahPDX Electrical 5 07-04-2009 12:13 PM
looking to replace a rotary switch Unregistered Electrical 1 03-31-2004 12:57 PM
