How To Remove The Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 12:13 PM   #1
Rewards Points: 164
How to remove the switch
I'm removing the switch to control this via a wall mounted switch, just as simple as black to black and white to white?
Thanks!
ryan50hrl is offline   Reply With Quote
Old 09-07-2012, 12:25 PM   #2
Rewards Points: 776
Well you could always leave the switch and just leave it the in on position. Looks like a bandsaw in a shop. Probably best not to disable a switch and have it inoperable. Could be confusing to a user and thus a safety risk if they try to kill the saw in an emergency and nothing happens.
Make sure you use a wall switch rated for proper HP of the motor. A residential grade 15A switch is typically only rated for a 1/2HP load. They make beefier switches for motors (typically listed as commercial grade). They are only a few dollars more expensive.
curiousB is offline   Reply With Quote
Old 09-07-2012, 01:49 PM   #3
Rewards Points: 164
It's actually for a dust collector, not the saw. The switch has gone bad and won't stay on. I already bought a 15 amp, motor control switch that's rated for the dust collector motor.
Old 09-07-2012, 07:32 PM   #4
Rewards Points: 164
Anyone?
Old 09-07-2012, 07:44 PM   #5
If its a single pole switch, all you need to do is take the two wires off the switch and nut them together.
Evstarr is offline   Reply With Quote
Old 09-07-2012, 08:41 PM   #6
Rewards Points: 164
There's 3 black and two white to the back of tw switch
Old 09-07-2012, 10:37 PM   #7
Msradell's Avatar
Rewards Points: 88
Based on that I'm assuming yours is wired like the top diagram in your picture. If that's the case then as you asked you just need to connect the 3 blacks together and the 2 whites.
Msradell is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Remove a switch timcsi Electrical 6 08-08-2012 08:56 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Remove light switch broadbear Electrical 2 03-29-2009 02:39 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
