How To Remove Light Bulb Casing - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 01:16 PM   #1
How to remove light bulb casing
I unscrewed a burnt light bulb and the outer metal casing of the screw-in part stayed in the light socket. How do I remove that so that I can put a new bulb in?
rhymer59 is offline   Reply With Quote
Old 03-10-2009, 03:12 PM   #2
Remodeling Contractor
use needle nose pliers, expand to the inside edges and turn it out.
Old 03-10-2009, 03:27 PM   #3
Use needle nose pliers as suggested, or crush it inward and try to unscrew with a flatter ended pliers.
rgsgww is offline   Reply With Quote
Old 03-10-2009, 04:33 PM   #4
Yes, you can actually tear the socket metal and peel it like an orange until the lamp socket gives up.
To make this tedious job exciting and test the health of your cardiac muscle, leave the power on (nah, just kidding).
Old 03-10-2009, 09:25 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
I think this is one of the main reasons this site has the disclosure statement on every forum thread just below the OP!
theatretch85 is offline   Reply With Quote
Old 03-10-2009, 09:35 PM   #6
or as they say in the GoodHouskeeping tips and tricks... so i heard...use a potato, jam it in the broken base and rotate your house counterclockwise.
unclduey is offline   Reply With Quote
Old 03-10-2009, 10:26 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
I'm with the needle nose guys. Works every time for me.
Speedy Petey is online now   Reply With Quote
Do they make light bulb converters that will still allow a light bulb? jimithing78 Electrical 15 11-29-2008 12:57 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 08:26 AM
Flourecent light bulb question shadango Electrical 7 06-28-2008 09:28 PM
how do I remove light and plug plates catara Painting 6 01-01-2008 11:29 PM
