How To Remove This Housing? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 11:23 AM   #1
How to remove this housing?
Hello there... I'm a complete newbie that is trying to put up a canister light. I removed the current light and this is the housing that I can't figure out how to remove??? I assume there should be a screw or two and it would be that simple, but I can't figure out how to remove it???
Thanks for any help!
Golf Pro Mike is offline   Reply With Quote
Old 05-26-2012, 11:28 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Its probably nailed on the outside of the box. Push up on the box with a screwdriver. You should be able to figure out what side of the box the joists are on, then pry it out.
Old 05-26-2012, 11:41 AM   #3
It is connected to the left side of the picture.... I didn't want to use force if it didn't call for it.
This just created another question..
When I pry this out, will there be room for a 6" canister if the previous 3-4" housing was nailed to a joist? I really didn't want to patch drywall. I just bought a remodel can?
Thank you for your help.
Old 05-26-2012, 11:44 AM   #4
k_buz's Avatar
You should be fine, although you won't be able to center the new can on the existing hole. You will have to have the edge of the new can on the edge of the joist.
Old 05-26-2012, 11:44 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The box is obviously nailed to a joist, so I highly recommend you probe around in the other direction to make sure the remodel can will fit with no obstructions... such as water pipes, blocking, etc...
Old 05-26-2012, 12:04 PM   #6
Licensed electrician
Rewards Points: 1,028
You might end up with a small amount of patching. The housing typically requires a 1/2" clearance from wood framing.
Old 05-26-2012, 05:46 PM   #7
Thanks everybody... I'll let you know what happens.
Old 05-26-2012, 09:33 PM   #8
Rewards Points: 264
If you go to Lowes or HD look in the electrical section for a similar box.
Seeing one out of the hole will help you figure it out.
7echo is offline   Reply With Quote
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 12:42 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
