Old 03-06-2011, 05:41 PM   #1
How Remove Electric Baseboard
I had an electric heating system removed from the house I bought and replaced it with an oil furnace but the electrician left one old electric baseboard still attached. I'm wondering if there's a way I can remove it myself. Is there any way to safely determine if it is still hooked up to the electricity in the house? Anything else I should be concerned about?
ncody71 is offline   Reply With Quote
Old 03-06-2011, 06:43 PM   #2
I=E/R
a7ecorsair's Avatar
Did these heaters have a separate circuit breaker panel or were they connected to the same panel that serves the house? Either way, did the electrician remove the breakers for the heaters?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
ncody71 (03-07-2011)
Old 03-06-2011, 07:19 PM   #3
They were on the same panel as the rest of the house. I think I've figured out which breakers went to the baseboards on the first floor - they are set to off. I don't know if the one remaining baseboard is connected to anything besides the wall at this point.
Old 03-06-2011, 08:31 PM   #4
Learning by Doing
Leah Frances's Avatar
Drive yourself down to a hardware store and buy a non-contact voltage tester. No guessing is allowed with electricity.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Old 03-06-2011, 08:56 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
setting a disconnected circuit's breaker to off is not acceptable. The wires need to be removed from the breaker and wire nuts put on them.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Electric baseboard problems shnevdorf Electrical 9 02-04-2010 10:53 PM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 05:59 PM
baseboard electric heaters? rick32 HVAC 1 04-01-2007 10:50 AM
