How To Reduce 50 Amp To 20 Amp On The Same Circult? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 09:35 PM   #1
How to reduce 50 amp to 20 amp on the same circult?
My wife has a tanning bed that is 220, 20 amp service. I also just bought a spa that is 240 50 amp service. I thought I might be able to piggy back off the spa circult instead of running a whole new line. The spa is on a 50 amp sub panel.
I guess my question is, is there anyway to reduce the amperage going to the tanning bed if they are on the same line? I know we can't tan and use the spa at the same time, and the spa cycles at night, so we are good there. Could I run another sub panel off the 50 amp and circult and use a 20amp breaker?
I don't want to run another line as it's a pain in the arse. Any help would be appreciated...
thanks!
Edbates2004 is offline   Reply With Quote
Old 04-18-2011, 09:39 PM   #2
joed's Avatar
Rewards Points: 12,852
If it is actually a sub panel then you can install a 20 amp breaker in it and add a line for the tanner.
Will the noise reduce if installiing drywall on a glassless window? baby327nd Windows and Doors 2 03-21-2011 08:55 PM
Would a drop ceiling reduce percussive walking noise from neibor above? fredonian Building & Construction 8 05-19-2009 03:23 PM
Need to reduce humidity in house creamaster HVAC 4 11-19-2008 04:03 AM
Can I shield or reduce the current being sensed by a Current Sensing Transducer? copper00 Electrical 13 08-04-2008 03:19 PM
Does Drylock waterproofing help reduce radon? nuadhu1 Remodeling 1 02-10-2008 06:47 AM
