How To Protect Myself While Using A Power Tool While Standing In Water? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 03:30 PM   #31
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Originally Posted by creeper View Post
22 responses...stirring the trolls pot
My first thought, even before reading any replies.
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (06-23-2013)
Old 06-23-2013, 03:47 PM   #32
Plumber
TheEplumber's Avatar
Rewards Points: 452
Originally Posted by Oso954 View Post
Adding to the pucker factor, anyone recognize 220 volts in Jim's second photo ?
I really want let this thread die-- but those guys need to be nominated for the Darwin Awards....
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 06-23-2013, 03:59 PM   #33
Electrical Contractor
kbsparky's Avatar
Folks who work on sanding the exterior of boats while standing in the water use either battery- or compressed air operated tools.
I imagine the same solution(s) would apply to one in your situation.
-KB
Old 06-23-2013, 06:48 PM   #34
Rewards Points: 6,652
Originally Posted by Gac66610 View Post
Why would you need a power tool in a wet shower?
Didn't you know that everyone uses power tools in showers, or in basements that are flooded. It is called being on the short end of the Gene pool.
Old 06-23-2013, 06:50 PM   #35
Originally Posted by JenniferWA View Post
Removing mineral deposits from the shower walls.
They actually make really good chemicals that will remove the mineral deposits, that you can get from Sam's Club, GFS, even Lowe's, Home Depot, Ace Hardware sells them.
Of course, if CLR, which is the best out there does not do it, I hear taking a hammer and tearing all the walls down to the studs works really good in these situations.
The Following User Says Thank You to gregzoll For This Useful Post:
RWolff (06-24-2013)
Old 06-23-2013, 06:52 PM   #36
There are many ineffective products on the market; I've tested a good number of them. I have a system that works and without scratching the glass, but I need to protect myself from electricity while I work. There are probably no battery operated tools with enough power for the job. Chemicals also are not possible in all situations + they are bad for health.
Looks like you have been sniffing way too many of them. All the chemicals that are for Mineral removal that is on the market work really well, you just need to follow the directions.
High Pressure Steam also works really well to remove the problem. Just make sure you have the door closed, vent fan off, and supply vent to the furnace closed, otherwise it does not work in getting rid of the problem.
RWolff (06-24-2013)
Old 06-23-2013, 06:55 PM   #37
How have you come to the conclusion that you will need four hours to sand hard water stains?? Odd that you have come up with a time.
Everyone knows that it takes four hours to do something like this. Just like everything in Chicago is only fifteen minutes away. That includes driving from the far NorthWest Suburbs to downtown, which is almost two hours away.
Old 06-23-2013, 06:57 PM   #38
Originally Posted by bobelectric View Post
I never heard of any Pro sanding tiles in a shower stall. Lets see the finished results.
Never have I either, unless they are removing the gloss off the tile or sealer, to repaint, or reseal.
Old 06-23-2013, 06:59 PM   #39
Usually air powered, so that they are not going to run out of juice.
Old 06-23-2013, 07:05 PM   #40
Roofmaster
Rewards Points: 2,172
A Lobotomy is the first thing that comes to mind.
The Following User Says Thank You to jagans For This Useful Post:
Old 06-23-2013, 08:11 PM   #41
Rewards Points: 168
Take a pressure washer to it..lol..would work though (low psi)
hidden 1 is offline   Reply With Quote
Old 06-23-2013, 08:50 PM   #42
A pressure washer that's just silly ...this is what you need
creeper is offline   Reply With Quote
The Following 3 Users Say Thank You to creeper For This Useful Post:
ddawg16 (06-24-2013), gregzoll (06-23-2013), RWolff (06-24-2013)
Old 06-24-2013, 09:07 AM   #43
Electrical Enthusiast
Rewards Points: 504
Kyle_in_rure is offline   Reply With Quote
Water standing in the backyard - clay soil gardening Landscaping & Lawn Care 10 05-05-2011 08:25 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-20-2009 12:53 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
