How To Protect Myself While Using A Power Tool While Standing In Water? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 07:56 PM   #16
Gymschu's Avatar
Rewards Points: 822
In the history of bad ideas, standing in a wet shower with power tools would rank #1.
The Following User Says Thank You to Gymschu For This Useful Post:
Kyle_in_rure (06-22-2013)
Old 06-22-2013, 08:38 PM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,938
"Chemicals" are not necessarily bad for your health. Hydrochloric (muriatic) acid removes pretty much all mineral deposits from pretty much anything, and doesn't damage most surfaces (marble, limestone, and travertine excepted). It smells very strong and is irritating, but is NOT TOXIC and is naturally produced in your stomach in huge quantities. CLR and Lime Away are gentler, but less effective. All of these options are way less dangerous than using power tools in the shower.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 06-22-2013, 10:17 PM   #18
"Hydrochloric (muriatic) acid"
I suggested the use of muriatic acid awhile back and was just about ran out of town on a rail.
Hardway is offline   Reply With Quote
Old 06-22-2013, 10:19 PM   #19
Rewards Points: 282
barkeeper's friend (oxalic acid) will get even the most stubborn hard water stains off....
standing in water with an electric buffer <<<<<<<< CLR < barkeeper's friend < Muriatic acid
jcrack_corn is offline   Reply With Quote
Old 06-23-2013, 12:03 AM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
I like the muriatic acid idea.....and it even works on trolls....
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
bbo (06-23-2013), gregzoll (06-23-2013), Gymschu (06-23-2013)
Old 06-23-2013, 06:28 AM   #21
Rewards Points: 3,130
What you want to do is just crazy. Have you ever seen someone electrocuted?? I have and trust me, it isn't pretty. Use an appropriate chemical like CLR and then get yourself a water softener. A clean shower isn't worth dying for.
Old 06-23-2013, 06:44 AM   #22
Gymschu's Avatar
Rewards Points: 822
P.S. Wouldn't it be easier to address the hard water issue so you wouldn't have to deal with removing these awful hard water stains in the 1st place?
Old 06-23-2013, 07:14 AM   #23
Rewards Points: 1,216
Battery operated tools, while working with one tool have the other battery charging. Keep switching. If you go with chemicals keep spraying it on a couple days maybe even hang wet fabric over the stains to hold the chemical in place while it soaks in.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 06-23-2013, 07:32 AM   #24
Civil Engineer
Rewards Points: 4,764
Air powered tools make a lot of sense. They are just as powerful at the point of use as electric tools, provided the pressure and flow of air is adequate. They work well in wet conditions, and in fact some of them work underwater (underwater chainsaws used in specialty logging and demolition comes to mind). And you will not get shocked using them. Most tool types have an air powered equivalent, often they cost more, but if properly built they are rugged and very reliable.
Old 06-23-2013, 07:37 AM   #25
Rewards Points: 1,192
I never heard of any Pro sanding tiles in a shower stall. Lets see the finished results.
bobelectric is offline   Reply With Quote
Old 06-23-2013, 01:48 PM   #26
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by JenniferWA View Post
I need to use a power tool in a shower with water turned on periodically. There will be water all over the shower and on my hands and feet. I need proper shoes and gloves that will protect me and enable me to do somewhat detailed work with my hands. Please help me know what to buy. Thank you!
WHY IN THE WORLD would the water need to be turned on periodically with you in there????
This is a serious question. I am very curious.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 06-23-2013, 01:54 PM   #27
Licensed electrician
Rewards Points: 1,608
Not even close.
When the shower is all clean you really need to relax.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Gymschu (06-23-2013), mpoulton (06-24-2013)
Old 06-23-2013, 02:00 PM   #28
22 responses...stirring the trolls pot
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
Speedy Petey (06-23-2013)
Old 06-23-2013, 02:18 PM   #29
Gymschu's Avatar
Rewards Points: 822
Good point, Creeper. Either "JenniferWA" died performing this task or "she" moved on to other chatrooms for more trolling activities.
Old 06-23-2013, 02:27 PM   #30
Oso954's Avatar
Rewards Points: 1,106
Adding to the pucker factor, anyone recognize 220 volts in Jim's second photo ?
Oso954 is offline   Reply With Quote
Water standing in the backyard - clay soil gardening Landscaping & Lawn Care 10 05-05-2011 07:25 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-19-2009 11:53 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
