How To Protect Myself While Using A Power Tool While Standing In Water? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 04:45 PM   #1
How to protect myself while using a power tool while standing in water?
I need to use a power tool in a shower with water turned on periodically. There will be water all over the shower and on my hands and feet. I need proper shoes and gloves that will protect me and enable me to do somewhat detailed work with my hands. Please help me know what to buy. Thank you!
JenniferWA is offline   Reply With Quote
Old 06-22-2013, 04:49 PM   #2
Resi EC
Rewards Points: 252
Why would you need a power tool in a wet shower?
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
gregzoll (06-23-2013)
Old 06-22-2013, 04:53 PM   #3
why an electrical tool in a shower
Removing mineral deposits from the shower walls.
Old 06-22-2013, 05:02 PM   #4
Rewards Points: 91
Use battery operated tools and / or chemicals.
Your other method could prove deadly.
George6488 is offline   Reply With Quote
The Following 3 Users Say Thank You to George6488 For This Useful Post:
Gymschu (06-22-2013), mpoulton (06-22-2013), RWolff (06-22-2013)
Old 06-22-2013, 05:14 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Did you try CLR cleaner?
No tools required.
sublime2 is offline   Reply With Quote
Old 06-22-2013, 05:17 PM   #6
There are many ineffective products on the market; I've tested a good number of them. I have a system that works and without scratching the glass, but I need to protect myself from electricity while I work. There are probably no battery operated tools with enough power for the job. Chemicals also are not possible in all situations + they are bad for health.
Old 06-22-2013, 05:34 PM   #7
Just call me Andrew
Rewards Points: 1,020
Good luck, but I doubt you'll find people giving you any advice that would lead you to use a power tool in water. Not in this forum anyway.
Andrew
secutanudu is offline   Reply With Quote
The Following 5 Users Say Thank You to secutanudu For This Useful Post:
gregzoll (06-23-2013), Gymschu (06-22-2013), Hardway (06-22-2013), J. V. (06-23-2013), old_squid (06-23-2013)
Old 06-22-2013, 05:35 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 568
I assume you haven't checked into battery tools- you'd be surprised
If I can use them in commercial construction all day long- you can certainly find one for cleaning shower.
Even an air tool would be safer.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
J. V. (06-23-2013), Kyle_in_rure (06-22-2013)
Old 06-22-2013, 05:41 PM   #9
Rewards Points: 13,468
Add a water softener, no more water stains.
Gymschu (06-23-2013)
Old 06-22-2013, 05:52 PM   #10
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Well, you put too many restrictions and road blocks on doing this, making it the impossible to do with complete safety, you'll have to decide if being dead is worth cleaning a shower wall using a/c power tools and something goes wrong.
RWolff is offline   Reply With Quote
Old 06-22-2013, 05:57 PM   #11
I will check into battery-powered tools, then. Thank you for the cautions and advice, everyone.
Old 06-22-2013, 06:26 PM   #12
which compressor?
How much power etc. would I need for an air-powered sander? I'll be "sanding" for potentially 4 hours.
Old 06-22-2013, 06:31 PM   #13
I'm 60 years old and have extremely hard water, never once have we ever used any form of power tool on anything in the bathroom.
A simple spray with something like "The Works" rinse it off and done.
Ring around the toilet? Get a primus stone.
Old 06-22-2013, 06:32 PM   #14
Also, will I need any gloves or boots if I used battery-powered?
I imagine that there's not enough power in a battery to do lots of harm, but maybe I still need some protection.
Old 06-22-2013, 07:01 PM   #15
How have you come to the conclusion that you will need four hours to sand hard water stains?? Odd that you have come up with a time.
creeper is offline   Reply With Quote
Water standing in the backyard - clay soil gardening Landscaping & Lawn Care 10 05-05-2011 07:25 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-19-2009 11:53 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
