How To Properly Test Grounding System - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 11:03 AM   #1
Rewards Points: 862
How to properly test grounding system
Good morning;
Since I have been thinking about installing whole-house surge-protection, I started thinking about my brother's house as well as the one I live in.
My brother has has a few incidents with blown electronics, probably during storms (not a direct hit).
I am now wondering whether there is something wrong with his grounding system.
I have not been to his house recently, and have never looked closely at his SE.
What equipment would be required to test the grounding system?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-03-2009, 11:11 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The testing equipment for checking the ground resistance is very expensive. It really is unnecessary to do this in my opinion. I would simply check for the properly installed GES at the service entrance. About all you can change after that is the number of ground rods or the type of supplemental electrode.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-03-2009, 11:29 AM   #3
Remodeling Contractor
you need a mega-meter. As posted too expensive. When you wife upsets you, let here go around and touch all the metal....
Old 02-03-2009, 11:44 AM   #4
Rewards Points: 862
I don't have a wife<g>, it's my brother's wife who will upset him, and me<g>
Next time I'm over there, I'll do a visual and maybe take a look inside the panel to make sure everything's Kosher.
Actually, I thought I had read here that testing a grounding system required expensive equipment, but I wanted to be sure.
FW
Old 02-03-2009, 11:59 AM   #5
Generally two ground rods placed 6 ft. apart is an excellent ground.
Problems with ground rods are someone hits a rock when driving one, and then they cut it off "short". So if you did not install the ground rod(s) or see them installed, this is possible. Not likely, but possible.
I've read about "counterfeit" ground rods which are not made of the correct metal. This could be a problem.
Then there are rocky areas where it is impossible to drive a ground rod, then special things must be done to get a good ground. Ask the locals what to do if this is the case in your area.
I like the idea of testing if there is a problem. Might call around and see how much it would cost for someone to test for you. Or maybe it will be cheaper to just drive an extra ground rod or two and connect them to the existing ground rod(s). Then you will know for sure you have at least two full length ground rods.
As for surge protection, I have a whole house surge protector and good quality power strip surge protectors at each outlet, which has an electronic gizmo. And I have two ground rods 6 ft. apart which I know are the full length. I have not had any problems with electronic stuff getting zapped.
On ground testing...
http://ecmweb.com/grounding/electric...ng_techniques/
Ground testers (not cheap!)...
http://www.specialized.net/ecommerce...stance+Testers
Counterfeit Ground Rods...
http://www.ul.com/newsroom/newsrel/nr012809.html
Cut off ground rods (about 2/3 way down page)
see "Ground rod cut off or short"...
http://www.inspect-ny.com/electric/E...Inspection.htm
Billy_Bob is offline   Reply With Quote
Upgrading Grounding System sweaty Electrical 28 08-18-2008 05:15 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
