Old 05-25-2011, 06:25 PM   #1
How to properly ground electric service
I am in the process of installing an exterior antenna and want to ground it properly. And to that point, I want to bond it to the electric service ground so it's to code. The electric service is currently only grounded on the interior to a cold water pipe. The ground rod for the antenna is probably 4 feet from the service entrance. Should I run an 6 gauge wire from the antenna ground rod and tap it to the metal conduit at the service entrance, or is there a better way? I was thinking I could add an exterior ground rod to the electric service below the meter and bond the two rods together underground. But then the question becomes where do I tap into the service ground? Can someone give some insight?
mac70pete is offline   Reply With Quote
Old 05-25-2011, 06:39 PM   #2
see article 810 in the nec.also refer to art 250.50.
oleguy74 is offline   Reply With Quote
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
electric current going to ground ? help PIGEONS Electrical 1 11-12-2010 07:09 PM
New service ground mark1 Electrical 7 06-10-2009 05:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
electric service in garage kelr Electrical 2 03-26-2005 09:38 PM
