How Old Is My Square D Qo Load Center - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 10:01 AM   #1
How old is my Square d qo load center
Selling my house,and the buyers think i put a new panel in without permit..
Panel was there when i bought house..but doesnt have inspection sticker..
It is a square d qo load center 40265-354-04 how do I determine how old it is?
The cover Cat#QOC20U100F Series SO1
Skipper 888 is offline   Reply With Quote
Old 08-25-2012, 10:22 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 820
What part of the country are you in?
Most PoCo's will not reconnect a meter without the go-ahead from the building and safety department....who will not give that go-ahead unless you had a permit.
How old is the house?
It could be the previous owner did it if the panel is in fact newer.....
Did you compare your panel to a neighbors? If they are the same...chances are it's original.
Old 08-25-2012, 10:23 AM   #3
Rewards Points: 6,652
It is not that old. Why, is something wrong with it, other than not having the sticker? Not every area inspects Electrical installs. What that means, is if they allow home owners, or licensed electricians to do the work, the city does not need to come in to inspect the work.
Old 08-25-2012, 10:48 AM   #4
Im in N.J. it is a newer panel...Just wanted to prove it was installed befoer i purschaced...wiitch was in 2000
Old 08-25-2012, 12:30 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You can't prove anything with just the age of the panel. WHY is this such an issue??
MAN I hate home inspectors!
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (08-25-2012)
Old 08-25-2012, 12:35 PM   #6
Master Electrician
if it was a main panel it was either done live or with a permit. Contact your municipality, they should have a record if it was permitted. It may just not have gotten the sticker.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-25-2012, 02:59 PM   #7
There is your problem, you are in Jersey. As for the panel, so what if it is from around the new Century. Not a problem, no issue.
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 12:28 PM
Square D Load Center Conversion George6488 Electrical 3 07-23-2012 05:31 PM
portable generator to load center old blue Electrical 1 07-06-2012 01:41 PM
Load Center Generater Interlock in Cook County, IL shilohqdog Electrical 2 02-20-2011 04:57 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
