How Much Wire To Leave In Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2007, 06:20 PM   #1
Lehigh Valley PA
Question
How much wire to leave in box?
How much wire are you required, or do you leave in a switch box or receptacle box?
I know to leave about 8" for rough inspection but how much should you have (or shouldn't have) for final inspection?
I have quite a bit after connecting the switches but don't really like cramming all that wire back into the box.
Is there a general rule for this?
The one box I have is a single gang with one GFCI in it.
The other box is a 3 gang with 4 switches in it. (one is a double)
Thanks.
Nhrafan is offline   Reply With Quote
Old 04-09-2007, 06:46 PM   #2
Electrician
Rewards Points: 760
I know in Canada, it is 6" left in the box for joints and connecting to devices.
darren is online now   Reply With Quote
Old 04-09-2007, 06:56 PM   #3
3 inches from the face of the box.
Master Electrician
jwhite is offline   Reply With Quote
Old 04-09-2007, 07:15 PM   #4
Lehigh Valley PA
Thanks guys!!1
Old 04-13-2007, 09:25 AM   #5
mt232's Avatar
is that after the recepticle is connected?
mt232 is offline   Reply With Quote
Old 04-13-2007, 04:44 PM   #6
300.14 does not specify. So I would have to say that it must always be able to extend 3 inches from the face of the box.
Master Electrician
Old 04-13-2007, 04:49 PM   #7
They're all fixer-uppers
J187's Avatar
Rewards Points: 502
And at least 6" inside right? So in the case of a shallow box or something the 6" is more prevelant? Is that right?
J187 is online now   Reply With Quote
Old 04-13-2007, 05:03 PM   #8
I would read the section to say that if any demsion of the box opening is less than 8 inches you use the 3 inch from the face of the box rule. If not then you use the 6 inch rule.
Master Electrician
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Extending length of wire wingman Electrical 7 03-05-2006 06:47 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
