How Much Wall Needs To Be Done For Final? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 07:48 AM   #1
I ask the impossible!
Rewards Points: 640
How much wall needs to be done for final?
For typical final, how far does the work on the wall need to be? Can electrical final be done with drywall hung? Can it be done before taping and sanding is done? If taping and sanding needs to be done can it be done before paint?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-04-2011, 08:26 AM   #2
Rewards Points: 1,448
Generally final inspection for electrical is done with the drywall in place and cover plates able to be put on the outlet boxes if not already put on (In the latter case the inspector may or may not take off a cover here and there to see that the wires were screwed or backstabbed correctly). The system must be ready to be energized (if not already energized).
Drywall does not need to be finished (taped, mudded, painted).
All this assumes that you had a rough inspection with no drywall or insulation and all the strung Romex cables visible.
Old 06-04-2011, 08:38 AM   #3
the Musigician
DangerMouse's Avatar
Mornin' Will..... I just passed my final elec. and the walls were finished. Mudded, painted, etc.
All devices and fixtures were installed and covers in place. I opened the door to the panel I installed is all.
5 minutes or so and $50.00 later he was gone and I had my green sticker.
DM
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
