How Much Voltage Loss Is Acceptable? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 08:54 AM   #1
Just call me Andrew
Rewards Points: 1,020
How much voltage loss is acceptable?
I understand how to easily calculate voltage drop using a calculator like this:
http://www.csgnetwork.com/voltagedropcalc.html
How do I know if the loss I calculate is acceptable? At what percent loss would one consider using larger wire? Or is it specifically determined by what you are going to be doing at the other end of the wire?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 02-18-2010, 09:27 AM   #2
I'm not sure code dictates what is allowed...I have heard anywhere from 3-5% is OK
But in can depend upon the use
Incandescent lights will work OK on lower voltage & will last longer
So a long run down a driveway the voltage drop might be OK
But if at the end of the run is an electronic gate/motor then voltage drop might not be OK
Old 02-18-2010, 10:21 AM   #3
Here's at least one source for additional information.
http://www.psihq.com/iread/faqvolt.htm
The basic summary is that the NEC wants there to be no more than a 5% voltage loss on the farthest outlet of a fully loaded circuit (6 volts) The FAQ page makes it sound like there isn't a code specification on the issue, just a footnoted recomendation.
HooKooDooKu is offline   Reply With Quote
Old 02-18-2010, 10:35 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
correct. The NEC does not demand anything concerning this. A FPN (fine print note) is only a recommendation, suggestion, or clarification. It holds no enforceable weight.
Take note that there is a suggest 3% max voltage drop on branch circuits
and a 5% max voltage drop on feeders and branch circuits combined.
and that is to the furthest outlet.
Old 02-18-2010, 10:36 AM   #5
Just call me Andrew
Thanks, good info here.
Andrew
Old 02-18-2010, 10:54 AM   #6
nap
You talking to me?
nap's Avatar
We try to give you your money's worth.
Old 02-18-2010, 11:01 AM   #7
Just call me Andrew
But i didn't pay any....wait a minute!
Andrew
Old 02-18-2010, 11:15 AM   #8
Please send $5 payment to
SendDaveonVacation@HoliDaves.com
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 09:01 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 09:38 AM
