How Much Lighting For Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 01:43 PM   #1
How much lighting for garage
how much lighting is need for a 660 sq feet garage with a 12 ft ceiling i was thinking of putting 6 or 8 100 watt bulbs
dizzy46 is offline   Reply With Quote
Old 11-17-2009, 01:46 PM   #2
If you want to be able to really see in the garage I would put up fluorescent light strips with shades on them to direct the light down.
Plumbvoltage is offline   Reply With Quote
Old 11-17-2009, 02:16 PM   #3
What are you going to use the garage for ?
Old 11-17-2009, 02:58 PM   #4
Master Electrician
Grimlock's Avatar
Use two 4' dual fluorescent lamp strip lights with 6000k temp lamps. Evenly space them out between the walls. You should then have enough light to take care of just about any tasks.
Get some fluorescent tube covers to protect from shattering glass all over the floor if they are ever hit/fall.
Grimlock is offline   Reply With Quote
Old 11-17-2009, 06:57 PM   #5
Lux light levels
Hospital ward at night 1
resi. living room 50
resi. toilets, hallways, 80 to 100
School classrooms, Kitchen work areas, office lighting 300 to 500
Garment manufacture - sewing, Supermarket 750
Instrument assembly 1500
Two 32w 4' tubes in a decorative troffer will give 600 lux on an 8 sq. ft. surface 5' directly below it, and it drops down to half that value at the edge of a 7'x7' area below the fixture.
A 75w/1130 lumens halogen flood light will produce 1700 lux over a 5' dia. circle, 5' below the lamp.
Old 11-17-2009, 07:06 PM   #6
This isn't 1950.
Fluorescent strips are the way to go.
Two, 4' or 8' strips would give you plenty of light.
Four would give you really good light.
220/221 is offline   Reply With Quote
Old 11-18-2009, 07:40 AM   #7
Licensed Engineer
Rewards Points: 171
Garage lighting
If I had the chance to do it all over again........
  • I would place a 4-ft fluorescent fixture, mounted crosswise, at the head of each parking stall. This will give you light for any engine bay work, even if you do nothing more than checking oil level and adding washer solution.
  • I would place a 4-ft fluorescent fixture, mounted crosswise, at the tail of each parking stall. This will give you light for loading things in the trunk of your vehicles.
I might even mount both of the above fixtures angled at 45 degrees to better throw the light where I need it.
  • I would place a 4-ft fluorexcent fixture, mounted lengthwise between each parking stall, at the mid-point of the garage.
Since it sounds like you have a 3 car garage, my recommendations would require 8 fixtures.
MI-Roger is offline   Reply With Quote
Old 11-18-2009, 08:32 AM   #8
I'm actually installing recessed cans in my garage
That way I can change the light bulb for more or less light
I have 3 T-8 fixtures that will go over the back part of the garage for more light if needed
But everything else will take a normal bulb & use CFL's for reduced electric use
Hopefully LED bulbs will come down in price in the future allowing me to further reduce power use
Also don't use the T-12's for flourescent, use T-8's at a min
They also make T-5 & T-4's
Old 11-18-2009, 09:36 AM   #9
Also be aware that some people do not have radio reception after installing a lot of flourescent bulbs
This can include cell phones
This seems to be due to cheap ballasts = HD & Lowes ?
So might be better to spend the $$ & buy better grade
Long thread on the garage site:
http://www.garagejournal.com/forum/s...ad.php?t=28982
I have lousy cell phone reception in my area as it is
I'm putting an old BIG TV antenna in some attic space for FM reception just in case
Old 11-18-2009, 10:34 AM   #10
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what are the dimensions of the area? If it is long and skinny, you will have a different layout and requirement than if it is square.
Old 11-18-2009, 03:05 PM   #11
660 sq. ft = 61.3 sq. meter.
8ea. 100w @ 18 lumens/w with 50% of the light lost on the ceiling = 7200 lumens.
7200/61.3 = 117 lux.
Old 11-18-2009, 05:15 PM   #12
nap
You talking to me?
nap's Avatar
sure but how do you want it distributed and what luminaire will do that for you.
If you have a 6 foot X 110 foot hall, the luminaire requirements, both design and placement, would be very different than if you have a 25 1/2 X 25 1/2 foot square room.
Obviously it is not a 6 X 110 foot garage. That was simply an extreme to impress the point that floor footprint is relevant.
You should also consider task specific lighting, especially in a garage. A workbench is quite common and the general lighting is rarely adequate for a workbench area.
Old 11-18-2009, 06:28 PM   #13
Avg. 117 lux assumed in my calc.
From the Web, 11 lux, min., for a parking garage.
For auto repair work, to avoid casting deep shadows, the OP may want handheld lights.
Old 11-19-2009, 07:06 AM   #14
Joe F's Avatar
Rewards Points: 294
In my 24' by 24' garage I installed four dual 4' flourescent fixtures and they work great. Two would not have been enough. Pay close attention to placement, 2 of my fixtures are partially blocked when the overhead door is up.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 11-19-2009, 10:11 AM   #15
So each troffer lights up a 12'x12' area. From a computer-generated plot Lithonia e-mailed me, I think you have 200 lux to 600 lux, depending on where you are standing. With two troffers, you'd have been down to 20 lux at the corners.
DIY Lighting Fixture stubits Electrical 11 10-13-2009 02:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
