How Much Electricity Would 2 Sump Pumps And A Battery Back Up Use? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 07:34 PM   #1
How much electricity would 2 sump pumps and a battery back up use?
Hello,
I just had a french drain installed in my home (two Zoeller M53's 1/3hp and a 10amp/12volt battery backup model 507)
My house gets little water during heavy rains, but I did want to waterproof the basement before finishing.
Anyway, if I have these plugged in at all times, is that a good idea (what about the battery back up)?
Should I only plug in if I know a heavy rain is coming to save electricity?
fieldsy1024 is offline   Reply With Quote
Old 04-01-2013, 07:38 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
They don't consume any electricity unless they are running. The battery backup may use a little but I'm sure it is probabely minimal.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-01-2013, 07:41 PM   #3
Okay cool, I was just worried if this suckers drain your electricity.
When they are pumping, do they use a lot (for instance something as powerful as one of those portable heaters)
Old 04-01-2013, 07:59 PM   #4
Roofmaster
Rewards Points: 2,172
Just look a the amperage rating on the plates. One amp equals about 100 watts, so just figure from there. Just think of a 100 watt light bulb. Electric element heaters use a lot of juice, as they are basically a dead short. Even a typical hair dryer uses like 1500 watts. 1 HP equals 745 watts. Sump pumps are usually like 1/4 or 1/3 HP. Not much juice. 1/3 hp= 248 watts?
2 and a half light bulbs.
Old 04-02-2013, 04:56 AM   #5
Thats all it would use up while pumping? 2 and a half bulbs? wow.
That is good to hear
If it were you, would you always keep the battery back up plugged in, or just charge it once a week or so?
Old 04-02-2013, 05:40 AM   #6
DIY staff
Rewards Points: 7,174
Keep the thing plugged in at all times-----you need to keep the battery charged----
The unit uses very little power----the charger is not much bigger that the one that charged your phone-----
Old 04-02-2013, 05:45 AM   #7
Rewards Points: 321
Is the battery backup designed specifically for the application? If it's a good one, it is designed to be left plugged in at all times. It will have an on-board "brain" that will keep the batteries in top condition. Read the manual that came with the unit and see what they recommend.
al_smelter is offline   Reply With Quote
The Following User Says Thank You to al_smelter For This Useful Post:
k_buz (04-02-2013)
Old 04-02-2013, 06:34 AM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
The standby charger probably wont use much power. Typical ones will charge at 2 amps 12 volts dc at certain intervals, I believe. I have 2 big 100AH marine batteries hooked up to an inverter charger and I don't notice any significant energy usage. The 300w+ worth of server equipment uses much more.
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
battery back up sump iamsaws Plumbing 3 06-01-2011 07:48 AM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 03:48 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
