How Much Electricity Can I Use In My Little Studio? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 02:14 PM   #1
How much electricity can I use in my little studio?
In the near future I plan to purchase 2 ballasts to power 2 400w hid lights, 4 timers 2 small oscillating fans, 2 small water pumps and an exhaust fan. but I'm concerned that my room can't handle all that. I live in a studio apartment so I only have 2 outlets in the room and intend to use a multi-strip. I took a look at the breaker switch and it has the following printed on it:
C 16
~230/400v
______
10000 |
______|
|3|
L7-16/1/C
Basically, I want to know if I can use all those appliances together safely and successfully and if so what types of appliances should I purchase (i.e. voltage) in order to use those appliances to their fullest capabilites.
All responses from professional electricians greatly appreciated. If you ain't a pro please don't waist my time or your's
strik90 is offline   Reply With Quote
Old 03-06-2012, 02:22 PM   #2
seansy59's Avatar
Rewards Points: 258
Hmmmmmm.......I sure hope we aren't doing anything "illegal" by the way your describing this.
seansy59 is offline   Reply With Quote
Old 03-06-2012, 09:29 PM   #3
Julius793's Avatar
The only way to figure it out is if you give us the wattage of every appliance. What I see so far is most likely 16a x 220v= 3520w.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
frenchelectrican (03-06-2012)
Old 03-06-2012, 09:30 PM   #4
Julius793's Avatar
Well It just isn't the states
Old 03-06-2012, 10:01 PM   #5
" Euro " electrician
frenchelectrican's Avatar
C 16
~230/400v
______
10000 |
______|
|3|
L7-16/1/C
I live in France so I am not sure which area ya from but let get to the chase you have Class C breaker rated at 16 amp and this is not a RCD breaker so you may have a older one our modern one are rated little differnt.
For the max wattage you will have no issue with it you can sling up much as 3520 watts but just don't go over 3 KW load on this one and sencie you are renting a flat ( apartment ) there you should talk to the landlord to see if they willing to add a addtional circuit or not.
Merci,
Marc
Old 03-06-2012, 10:18 PM   #6
Illegal in your state perhaps....
LooseSCruz is offline   Reply With Quote
Film / Photo Studio Interior Design BryanRoberts Interior Decorating 5 11-30-2011 06:31 PM
What requires electricity? pcampbell HVAC 3 11-05-2011 12:39 PM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 04:23 PM
Is there a way to tell what's using the electricity from panel? Piedmont Electrical 9 02-12-2009 01:04 AM
Heating a detached studio WShawn Electrical 7 04-04-2008 08:21 PM
