How Much Does 200' Of Triplex Weigh?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 06:33 PM   #1
Rewards Points: 562
How much does 200' of triplex weigh??
I am trying to reside a house and wondering HOW to work around the elctrical service wires. There is about 200 ' of it from the pole to the house,,,hanging on a screw in insulator. HOW do you work around that? how do you take that wire off and put back on?? It isnt a fast job its gonna take days and days,like maybe weeks. OR cut around that trim board its screwed to and leave it there till get that high with siding. Mostly just doing soffit and fascia now, then tyvek,then window then main part of siding.
Main problem is this house is occupied,they need juice. the wires span over the alley so cant leave them down. Wondered IF they were so heavy they would jerk me off the ladder to take them down and put back up. It is 2 covered wires wound around a single cable type wire, bare,(small house,basic wires from 40 years ago!!)
4just1don is offline   Reply With Quote
Old 05-05-2009, 06:40 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
DO NOT touch them. This is WAY out of the scope of your work.
Either side around them or have an electrician or the POCO come out and remove them. Then you can side and then install a new POA then they can re-attach.
Speedy Petey is online now   Reply With Quote
Old 05-05-2009, 06:51 PM   #3
Have the POCO come out & move the wire to a new connection
Have the new trim block in place & ready
Around here the want an electric permit pulled if the electric has to be touched during siding. My last Inspectopr required the POCO come out & cover the wire to my last house during re-roofing. If I stood up I could hit the wire very easily
200' - Fuggetaboutit
I moved the cable only - 73' long to a new connection
That was heavy/hard enough
Old 05-05-2009, 10:18 PM   #4
" Euro " electrician
frenchelectrican's Avatar
60 Metre (200 ft ) that is pretty serious drop distance.
DO NOT TOUCH THE POCO CONDUCTORS!!!
just call the POCO they will come out and deal with that for you for your safety sake.
Merci,Marc
Triplex Outlets jamiedolan Electrical 33 10-14-2008 07:07 PM
How much does a 5 ton air handler weigh? 737Pilot HVAC 8 09-11-2008 09:08 PM
Splice triplex line??????? klaaar Electrical 15 11-26-2007 10:58 PM
How much does 5/8 drywall weigh? sedwick Building & Construction 12 10-07-2006 05:20 PM
