Old 03-03-2007, 09:36 PM   #1
How much 14/2
i want to wire a house. about 2400 square feet. How much 14/2 wire should i purchase? buddy told me 450m does this sound right?
Sparky_zoso is offline   Reply With Quote
Old 03-04-2007, 12:04 PM   #2
Electrical Contractor
How much 14/2
Depending where you are located, states or canada. In the states you can not use only 14/2. Some areas of your house will require 12/2, such as bath's, kitchens, laundry rooms.
Why do you have to buy all of it at one time anyway?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-04-2007, 01:42 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
How much 14/2
I agree with JBfan. The question is much to vague.
Is this a complete re-wire job? If so you will need quite a bit of #12 for bath and kitchen receptacle wiring.
Some will say use only #12 and larger. I am NOT one of them.
#14 is perfectly fine for many general receptacle circuits as long as not too many devices are placed on a circuit. I usually stay under 10 "items" per 15 amp circuit.
If I were starting from scratch with no stock on hand I'd start with 1000' of 14/2, 250'-500' of 14/3 and 500'-1000' of 12/2.
Old 03-04-2007, 10:10 PM   #4
RippySkippy's Avatar
How much 14/2
I wired my house house this past fall...new construction...2238 ft2. SP, numbers are close...I used 1500 ft each of 12-2 and 14-2; 500 ft of 14-3 and I think about 150 ft of 12-3 (3 way switched outlets). I purchased 1000 rolls and will use the rest in the basement and garage wiring.
Rip
RippySkippy is offline   Reply With Quote
Multiple lights/ceiling fans on 14/2?? sleepy23 Electrical 5 05-10-2007 11:27 AM
Moving from 12/2 to 14/2 bbarnhart Electrical 4 12-04-2005 07:26 PM
