How Much? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 11:57 AM   #1
How much?
How much does it usually cost to rewire a 2 bdrm full basement with an upstairs home
Cottonhb is offline   Reply With Quote
Old 12-13-2011, 11:59 AM   #2
It had a fuse box with old wiring
Old 12-13-2011, 12:27 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
$13.00.
I hope this helps.
Andy.
AndyGump is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyGump For This Useful Post:
gregzoll (12-13-2011), Speedy Petey (12-14-2011)
Old 12-13-2011, 12:31 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I'm sure an electrician (I'm definitely not) would have to see what he has to tie into, if the panels big enough, accessibility, and many more factors. New construction, they have their set prices, but not remodels or add-ons.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 12:47 PM   #5
Julius793's Avatar
That's to broad to answer best would be if you would supply more info
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-13-2011, 03:45 PM   #6
Going to need breaker box still using fuses, and new wiring through out house the upstairs has no wiring want to put lights and outlets, house still has aluminum wiring, just bought the house its so out dated
Old 12-13-2011, 03:48 PM   #7
Military Mom of 4
Snav's Avatar
Do you mean a DIY estimate (which requires knowing how much wire to figure cost based on length - and how many connections to factor in other materials like wing nuts and blah blah blah)
Or are you looking for a pro-estimate?
For a pro-estimate you neeed to ask a pro.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-13-2011, 03:50 PM   #8
That sounds like a hefty laundry list. It's highly unlikely that anyone on an internet forum will be able to give you an accurate estimate sight-unseen. There's a lot of variables involved. Contact two or three local licensed electricians and have them come write-up some detailed estimates for you, including materials and labor.
clashley is offline   Reply With Quote
Old 12-13-2011, 03:50 PM   #9
Disabled wood vet
titanoman's Avatar
I think a "pro" would probably bid it time and material.
Old 12-13-2011, 04:27 PM   #10
Julius793's Avatar
Some electricians will do flat fee with a point system. If you give me a comprehensive list of the number of outlets, switches, lights, Ect I can try and give you an idea
Old 12-13-2011, 04:29 PM   #11
Rewards Points: 6,652
Depends on how many cases of beer it takes. Now, if you look around your local streets with those people walking with carts full of "scrap" copper, they will happily rewire your home for you.
The Following User Says Thank You to gregzoll For This Useful Post:
AndyGump (12-13-2011)
Old 12-13-2011, 06:26 PM   #12
Well thank you all! There is 5 outlets between the 2 bdrms, none in bathroom,3 n LR, kitch has 4 only are hooked.up, sunroom has 3.. Now the basement I'm still not sure how many are hooked up and not hooked up but there are 8 outlets, now there are only 4 light switches in the house, all rooms have chains on the lights it is a nightmare
Old 12-13-2011, 06:52 PM   #13
DIY staff
Rewards Points: 7,174
Are you in the USA ,Canada,Union of South Africa, New Zeland or Australia?
That might make a difference in pricing,too.
Old 12-14-2011, 01:20 AM   #14
Usa, indiana
Old 12-14-2011, 04:43 AM   #15
DIY staff
You should call a couple of electricians and start getting estimates---Indiana has a much lower labor rate than Illinois---also,you can use Romex wiring--which is less than the conduit I am required to use.
The new service box and mast must be done by a licensed electrician --There may be some of the wiring you could do yourself---Mike---
