Old 02-27-2013, 10:00 PM   #1
How to mend underground sprinkler electrical wire
Some digging over a sprinkler pipe resulted in a broken pipe and a cut electrical wire. There are three wires(one red, two white) that run along the sprinkler pipe. I assume these supply 24 volts to the underground manifold box.
I know how to repair the pvc. What's a good way to mend the electrical wire (in a water tight way)?
diyatx is offline   Reply With Quote
Old 02-28-2013, 02:47 AM   #2
Semi-Pro Electro-Geek
There are direct-bury connectors that are made specifically for sprinkler lines. Some are push-in, some are twist-on. Just get a foot or so of extra wire, and connect it in between the cut ends.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
diyatx (02-28-2013)
Phone wire along side of electrical wiring DiegoJames Electrical 7 07-10-2012 06:21 PM
Underground power wire cut to garage. timrec Electrical 14 06-20-2012 09:43 PM
Ground Wire in Electrical Outlet Box - Where does it go? jgiannis Electrical 3 06-19-2012 03:12 PM
Can Electrical Wire go on the I-Beam thebrandnewguy Electrical 8 08-12-2011 11:16 PM
dishwasher electrical wire feb Electrical 31 04-12-2008 11:04 AM
