How To Measure Cabling When Pulling Multiple At Once? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 10:55 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
How to measure cabling when pulling multiple at once?
Figured I'd ask here as I'm sure it applies to electrical the same as it applies to data cabling. What is the best way to measure how long to make cables when pulling say, 4 at once using fish line? Since I have to precut them from the spool and not just pull directly from it, I don't want to make them too small or way too big.
I'm thinking, just trace out where it will go with a measuring tape marking all dimensions down then ball park it while adding a few feet, but wondering if there's a better way. Or should I try to just pull one at a time directly from the spool instead of pulling with the fish line? The 2nd way may be harder as I need to try to shove it down the hole I can't see, but is this how most people will do it?
Old 09-29-2009, 11:00 PM   #2
Pull a fish line 1st
Then measure the fish line
Old 09-29-2009, 11:01 PM   #3
run your fishtape to where you want to go. Mark it and pull it back. Now cut the wire to length using the fishtape.
bervin306 is offline   Reply With Quote
Old 09-29-2009, 11:09 PM   #4
Wire Chewer
Rewards Points: 46
wow so simple never even thought of doing that. I will mark the one that is already put in there then measure, cut, and reput the tape. For most jacks I can probably easily do one cable at a time, but the outside wall is trickier.
Old 09-30-2009, 12:07 AM   #5
If you do a lot of this sort of thing you can get "conduit measuring tape" which is marked every foot. The tape is used both to measure the length of the conduit and to pull the wires through.
Matsukaze is offline   Reply With Quote
Old 09-30-2009, 11:06 PM   #6
THAT is a smart new tool. The next tape I buy will be one of those......unless it's a bunch more money.
220/221 is offline   Reply With Quote
Old 09-30-2009, 11:38 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
New? It's been around as long as I can remember. I think you might be mistaken as to what is meant. I believe he means something like this:
Old 10-01-2009, 05:29 PM   #8
Electrician
Rewards Points: 760
When you push your fishtape in to get the measurment, tie a string on the fish tape when you pull it out. This way all you have to do is tie the fish tape back on and pull on the string.
darren is offline   Reply With Quote
Old 10-01-2009, 09:23 PM   #9
I read "condiut measuring fish tape".
I thought he was referring to the new Ideal 250' fish tape with laser etched foot markings.
Old 10-01-2009, 10:26 PM   #10
nap
You talking to me?
nap's Avatar
does it have a tally sheet to mark off where it starts after you break the end off a couple times?
Laser Measure? kimberland30 Tools 3 04-17-2009 09:36 AM
Best way to measure house? Wall to wall, interior, wall thickness, etc? RyanD General DIY Discussions 2 04-07-2009 12:17 PM
Suspended Ceiling - measure up or down? Woodcutter Remodeling 8 02-28-2009 06:53 AM
How to measure for new pre-hung interior doors jencampo Carpentry 3 03-25-2008 01:49 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
