How Many Wires Through A Hole - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2008, 05:51 PM   #1
Rewards Points: 274
how many wires through a hole
How many wires (romex) are you allowed to pull through a hole in the top plate? Thanks
ugabulldog is offline   Reply With Quote
Old 06-29-2008, 07:45 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Oh boy. Contentious issue.
Let's just say up to four cables (#14 thru #10) and you are clear of any derating issues that would restrict you.
To those thinking it, I know less than this requires derating, but not so much that it would require any action such as down sizing breakers or upsizing wire.
Old 06-29-2008, 08:05 PM   #3
Rewards Points: 274
I have three #12 wires, just making sure I didn't need to drill another hole and re-pull wire.
Old 06-30-2008, 07:39 AM   #4
When is fishing season?
CowboyAndy's Avatar
Petey, does the size of the hole matter? I mean really, 4 10-2 cables through a 1/2 in hole aint happpenin physically, but if you could get them through, it wouldnt be a problem? This is one area I REALLY need to learn more about...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 06-30-2008, 01:08 PM   #5
Power Gen/RS Engineer
Rewards Points: 566
Most male electricians would say yes, while most woman electricians would disagree.
Sorry-There was NO WAY that I could resist!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-30-2008, 02:15 PM   #6
Since Jimmy already stole the joke I'll have to give the serious answer.
No, there is no restriction as to hole size. Other than building codes that is.
The NEC does not care what size hole you drill.
Old 06-30-2008, 02:35 PM   #7
Licensed Pro
Just ask any plumber!
Old 07-02-2008, 11:47 PM   #8
liscenced electrician
Rewards Points: 538
if you can physically fit it in a hole, your fine. Unless your talking about boring a 2 inch hole and running half your houses circuits through it, then youll get called on it
jimmy21 is offline   Reply With Quote
Old 07-03-2008, 05:36 AM   #9
Oh really? I have some certain text that says different.
Old 07-03-2008, 05:18 PM   #10
Rewards Points: 538
technically your supposed to de-rate, but an inspector would be getting really nitpicky and i've never been called on it, or even have it be an issue. I did work with someone who would bore 2 inch holes all the way down a house, like i was saying and run like 10 12-2 through it, and the inspector really didn't like that
Old 07-03-2008, 08:30 PM   #11
Hey, I've never been called on it either, and I DID work for guys who would do just what you describe.
I just do what is right and I don't have to worry about it at all. If I do get called I like to know the code so I can either defend myself if I know I am right, or get red faced if I make a mistake.
Old 07-03-2008, 10:09 PM   #12
Electrician
The only problem is when you fire- or draft-stopped the hole, then 334.80 kicks in, of course this is only for type NM cables.
chris75 is offline   Reply With Quote
Old 07-04-2008, 10:39 AM   #13
$J0
Put all in same hole. 7/8" would be fine. Too many wires in too small of a hole causes heat. Form of "bunching"
$J0 is offline   Reply With Quote
Old 07-04-2008, 08:07 PM   #14
Derating is basically reducing the current carrying capacity of the wire because it will be subjected to too much heat right?
If you have to yank them through and risk damaging the outer jacket of the romex drill another hole.
Is there a code for this guys? I am an industrial/ commercial guy? Does the AHJ determine this ever?
Stavop is offline   Reply With Quote
Old 07-04-2008, 08:53 PM   #15
Yes. It's all in Art. 334.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
