How Many Wires In A Single Gang Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 12:48 PM   #1
How many wires in a single gang box?
I am wiring new basement plugs and have a homerun coming from panel into single gang box. The box is in the middle of the wall and I want to go right and left from there to install additional receptacles.
There are 4 holes in the blue box 2 top 2 bottom so is it ok to have 1 in 2 going out? Or do I need to install a double gang box to have room for the extra wire? Or install a junction box first?
jdtox is offline   Reply With Quote
Old 10-04-2012, 01:09 PM   #2
joed's Avatar
Rewards Points: 12,854
Depends on the gauge of the wire and the size of the box.
The Following User Says Thank You to joed For This Useful Post:
electures (10-04-2012)
Old 10-04-2012, 02:33 PM   #3
14-2 wire and is a standard single gang blue box. not shallow not extra deep.
Old 10-04-2012, 03:59 PM   #4
Rewards Points: 77
If you look very closely inside the box, it should indicate the cubic inches of the box. Please provide this number and we can tell you the number of conductors that can be placed in there.
Please note that there are additional considerations, like whether the box itself will have a receptacle in it (a receptacle typically counts as 2 conductors).
patented is offline   Reply With Quote
Old 10-05-2012, 08:39 AM   #5
Rewards Points: 672
You haven't received much feedback because this subject has been covered ad nauseum here. As Pat said, in every box there is a cubic inch measurement that is a max the box can hold. A simple google or DIY Chatroom search on electric box count will tell you how to count.
B
Beepster is offline   Reply With Quote
Old 10-05-2012, 10:37 AM   #6
Master Electrician
6 cables plus device is fine in a 2 1/2 inch deep box. I don't think wirenuts count in the u.s for fill but I'm sure someone south of border will be along shortly to confirm that.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Maximum wires in box for ceiling fan connection fan13 Electrical 10 07-29-2012 10:11 AM
Single Switch 6 wires? Mikemonica Electrical 3 12-11-2011 09:54 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Help with single pole switch ballutster Electrical 2 10-13-2008 07:57 PM
