How Many Wires In Romex V. Extension Cord? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 05:31 PM   #16
Learning by Doing
Leah Frances's Avatar
Originally Posted by DangerMouse View Post
Sure seems overkill for speaker wire!
DM
According to DH, "It's cheap and it's reviewed well."
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-31-2010, 05:43 PM   #17
To keep the damping factor high you're supposed to use heavy gauge wire for speaker wire.
http://en.wikipedia.org/wiki/Damping_factor
Old 05-31-2010, 06:12 PM   #18
the Musigician
DangerMouse's Avatar
Originally Posted by Leah Frances View Post
That is exactly what he wants to do.
twist all wires into one wire? this makes no sense. if he wants to run stereo lines using this cable, it'd work fine, but why twist into one line?
DM
Old 05-31-2010, 06:25 PM   #19
Learning by Doing
DM
As with most things with my sweet sweet husband the answer is merely, "Why not?"
Old 05-31-2010, 07:00 PM   #20
Rewards Points: 160
I have started using NM for speaker wire in new installs. It's much cheaper than stranded speaker wire and is quite sufficient.
I would never try to make three conductors into one though.
Old 06-01-2010, 12:31 AM   #21
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I might have some 500 MCM laying around for him to use
Old 06-01-2010, 12:34 AM   #22
" Euro " electrician
frenchelectrican's Avatar
Merde!! there goes my windows with mega sized speaker hooked up with 240mm² { 500MCM } cable.
Merci,Marc
Old 06-01-2010, 05:43 AM   #23
Master Electrician
Rewards Points: 3,874
He wants to use it as speaker wire. Sheesh.
Check the UL White Book. Probably not listed for in wall use.
brric is offline   Reply With Quote
Old 06-01-2010, 06:41 PM   #24
Learning by Doing
Merci,Marc
Wait a minute. We can curse in French.?!?
Old 06-01-2010, 06:42 PM   #25
Learning by Doing
Yeah, he and I have had this discussion. He's running it under the floor through the basement, so as far as he's concerned, it's not in a wall. HEADSMACK.
Old 06-01-2010, 06:45 PM   #26
We can, but may we?
Old 06-01-2010, 10:02 PM   #27
I don't know how the mod squad will taste this but let's keep it clean anyway.
Sorry about that.
Merci,Marc
Old 06-02-2010, 06:41 AM   #28
Just call me Andrew
Rewards Points: 1,020
Originally Posted by Yoyizit View Post
DVM and a 100w incand. lamp
I think this is your solution to every problem!
Andrew
secutanudu is offline   Reply With Quote
Old 06-02-2010, 11:01 AM   #29
Originally Posted by secutanudu View Post
I think this is your solution to every [electrical] problem!
I have a 100w, 100 ohm rheostat that I got at a Hamfest, but everyone has lamps and hair dryers
It helps to have a calculator, too. . .
You use these to get the [Léon Charles] Thévenin equivalent circuit impedance.
http://en.wikipedia.org/wiki/Thévenin's_theorem
Old 06-02-2010, 05:28 PM   #30
Master Electrician
he'd be better off using two of the wires in the extension cord seperate. The wires themselves are fine strands with is better for sound plus they're twisted all through the cord which will also help to cancel out any interferance that might be encountered. I used to build car stereo's in my younger days lol. The look on the rep from pioneers face when he asked how i got the sound dampened so well in my car and i showed him the duct insulation all through it was worth every penny spent
andrew79 is offline   Reply With Quote
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 11:23 AM
Extension Cord Mod chazz Electrical 2 01-15-2010 05:50 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
Multi ended extension cord Rze Electrical 6 09-22-2008 10:17 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 09:21 PM
