-   -   How many wires in Romex v. extension cord? (http://www.diychatroom.com/f18/how-many-wires-romex-v-extension-cord-72449/)
Leah Frances 05-31-2010 12:11 AM
Sorry Dave, for the complicated Title.
Please settle a dispute between me and DH. How many wires are in a Romex cable? My understanding is that 12/2 = white, black, and ground. 12/3 = white, black, red, and ground. Right?
DH has found some extension cord that he wants to use as speaker wire (don't ask...) it is labeled 14/3. What does that mean? Why aren't they standardized?
nap 05-31-2010 12:16 AM
How many do you want in the Romex? If it is XX/2 =G there are 3. If it is XX/3 + g there are 4. You can also get 2 circuit with 2 neutrals + g so it would have 5. I don't know if they make more but it would be possible.
to your 2 types of NM (Romex is a TM'd name used to be owned by the Rome Wire Co and now owned by South wire (I think)) you count and color would be correct. The ground would be bare
extension cord or SO cord counts the ground within the number so a 12/3 SO cord would have a black, a white and a green insulated conductor
and they are standardized. NM doesn't count the ground and SO cord does. Isn't that standardized?
Leah Frances 05-31-2010 12:18 AM
So NM cable 14/3 = four wires inside
extension cord 14/3 = three wires inside?
Doesn't that seem weird to anyone else?
nap 05-31-2010 12:24 AM
L
eah Frances;449100]So NM cable 14/3 = four wires inside
yes
yes
I guess it's just a trade thing. I'm thinking it goes back to when NM didn't have ground wire in them and then they tossed in the un-insulated wire.
so, rather than calling 12/2 NM 12/3 NM when you put the ground wire in, to avoid confusion, they called it 12/2 WG (with ground).
the ground wire in SO could be used to carry current if need be. The ground in NM cannot as it is not insulated other than the outer sheath.
Leah Frances 05-31-2010 12:54 AM
Thanks, but I still think it's stupid.
Leah Frances 05-31-2010 01:08 AM
Ok. Here's another question. DH wants to "combine" each of the wires in the 14/3 extension cord and wants to know what that equals.
Leah Frances 05-31-2010 01:11 AM
Yes, I know this is STUPID.
nap 05-31-2010 01:14 AM
Not sure what you mean. Are you asking what size of wire he would have if he interconnected all 3 #14 wires together into 1?
Leah Frances 05-31-2010 01:20 AM
That is exactly what he wants to do.
nap 05-31-2010 01:32 AM
well, let's see.
#14 wire is 4110 circular mils so 3 times that would be 12330 circular mils. #10 wire is 10380 circular mils and #8 is 16510 circular mils so that would put him at about a #9 wire.
frenchelectrican 05-31-2010 02:54 AM
let me try that in metric verison .,
2.5mm˛ X 3 = 7.5mm˛ so the size will be roughly between #10 and #8 AWG size
and I know you will ask me if I have any wire size close to that size if 8mm˛ the answer is no unless you get into electric motor or transfomer that about it.
Merci,Marc
Yoyizit 05-31-2010 08:56 AM
If he twists them together over their whole length he might get somewhat equal current sharing and if he has a DVM and a 100w incand. lamp he can check how equal.
fpeftw 05-31-2010 10:38 AM
They're counting the insulated conductors.
Leah Frances 05-31-2010 04:44 PM
He wants to use it as speaker wire. Sheesh.
DangerMouse 05-31-2010 06:13 PM
Sure seems overkill for speaker wire!
DM
