How Many Wires In 1/2" Conduit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 11:28 PM   #16
Rewards Points: 2,350
Originally Posted by chris75 View Post
I agree and disagree. Its a proven fact that the conduit is a better ground then any wire pulled through it, I dont see a fitting just coming loose, its either tight or someone loosened it, but what ever, I always pull a EGC...
Yes, almost all line to case fault current travels along the conduit, even with an EGC. But I have seen personally, time after time after time how connectors and couplings never even get tightened in the first place. Or their set screws. It's like someone just stuck the pipe in the fitting and walked away. I have spied on journeymen tighten a connector to a box just hand tight, same with compression connectors and couplings. Never put a tool on it. Ridiculous.
InPhase277
Old 02-26-2008, 02:57 PM   #17
Union Electrician
goose134's Avatar
goose, have you checked prices lately. die-cast were about 3 times the cost of the steel fitting a while back. Had a run of very poor quality steel fittings about 7 years ago. Kind of turned me off of them. The ones around here now are pretty good and I actually prefer them.
I had a feeling that pricing played into it. But if that were the only reason I think it would be more likely that the contractors would simply start using them. I think what I'm seeing is more and more architects specifying them. I do know that steel's grounding characteristics are superior to the die cast fittings. I think I must have run into the same batch as you did. The compression stuff is still iffy in my opinion.
goose134 is offline   Reply With Quote
Old 02-26-2008, 03:37 PM   #18
Electrician
InPhase277
I agree 100% with your comment, the only prob I have is that I have seen some crappy splices as well... but lets face it, some people are just not cut out for this work.
chris75 is offline   Reply With Quote
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Conduit issues - help needed nymackem Electrical 19 11-05-2007 06:45 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
conduit size and NEC stagger19 Electrical 4 08-20-2006 09:44 AM
