How Many Wires In 1/2 Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 09:12 AM   #1
how many wires in 1/2 conduit
can i fit 3 #8 and 1 #10 in 1/2 grey underground conduit Im not sure if its sch 40 or 80.
bbddt is offline   Reply With Quote
Old 04-30-2011, 09:34 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Legally? No.
Kyle
Old 04-30-2011, 09:53 AM   #3
can i use a 12 instead of a10 it will be for the ground
Old 04-30-2011, 09:55 AM   #4
Rewards Points: 320
No. 1/2" schedule 40 will only fit (3) #8 thhn/thwn's. 1/2" schedule 80 will only fit (2) #8 thhn/thwn's. You need at least 3/4" for schedule 40 or 80. Those are minimums. I suggest going with 1" pipe to allow for ease of pulling wire and for possible future upgrades.
teamo is offline   Reply With Quote
Old 04-30-2011, 09:59 AM   #5
Rewards Points: 320
what are you running? Is this a sub-panel? What size breaker are you using?
Old 04-30-2011, 10:01 AM   #6
yeah i wish i would have thought of 1" before . ok thank you
Old 04-30-2011, 10:02 AM   #7
would like to do sub panel but done think i have large enough conduit
Old 04-30-2011, 10:05 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
For the 40 amp circuit you're looking to get to the shed, no. I know you're trying to utilize the 1/2" PVC already in the ground, but if you want a 40A sub-panel in the shed, you're going to have to run something else.
Kyle
Old 04-30-2011, 10:07 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
See other thread...
electric for shed
Kyle
Old 04-30-2011, 11:03 AM   #10
" Euro " electrician
frenchelectrican's Avatar
Short et sweet answer is no on both counts.
As other members allready address the conduit count and the other thing is that you can not use #12 for grounding purpose with #8 conductors you have to use #10 which that will work fine unless pretty long distance then you have to bump up to match the other conductor lines size.
Merci,
Marc
Old 04-30-2011, 10:14 PM   #11
Scared Electrician
Saturday Cowboy's Avatar
I'll given you a hint that chart in the back of the code book that says how many wires you can get in a given pipe, is just about as many as is physically possible.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Is it legal to run wires on the ground, in conduit? Red Squirrel Electrical 20 02-22-2011 03:59 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
How many wires in 1/2" conduit? alvanos Electrical 17 02-26-2008 04:37 PM
