-   -   how many wires in 1/2 conduit (http://www.diychatroom.com/f18/how-many-wires-1-2-conduit-103180/)
bbddt 04-30-2011 09:12 AM
can i fit 3 #8 and 1 #10 in 1/2 grey underground conduit Im not sure if its sch 40 or 80.
SD515 04-30-2011 09:34 AM
Legally? No.
bbddt 04-30-2011 09:53 AM
can i use a 12 instead of a10 it will be for the ground
teamo 04-30-2011 09:55 AM
No. 1/2" schedule 40 will only fit (3) #8 thhn/thwn's. 1/2" schedule 80 will only fit (2) #8 thhn/thwn's. You need at least 3/4" for schedule 40 or 80. Those are minimums. I suggest going with 1" pipe to allow for ease of pulling wire and for possible future upgrades.
teamo 04-30-2011 09:59 AM
what are you running? Is this a sub-panel? What size breaker are you using?
bbddt 04-30-2011 10:01 AM
yeah i wish i would have thought of 1" before . ok thank you
bbddt 04-30-2011 10:02 AM
would like to do sub panel but done think i have large enough conduit
SD515 04-30-2011 10:05 AM
For the 40 amp circuit you're looking to get to the shed, no. I know you're trying to utilize the 1/2" PVC already in the ground, but if you want a 40A sub-panel in the shed, you're going to have to run something else.
SD515 04-30-2011 10:07 AM
See other thread...
http://www.diychatroom.com/f18/electric-shed-102916/
frenchelectrican 04-30-2011 11:03 AM
Short et sweet answer is no on both counts.
As other members allready address the conduit count and the other thing is that you can not use #12 for grounding purpose with #8 conductors you have to use #10 which that will work fine unless pretty long distance then you have to bump up to match the other conductor lines size.
Merci,
Marc
Saturday Cowboy 04-30-2011 10:14 PM
I'll given you a hint that chart in the back of the code book that says how many wires you can get in a given pipe, is just about as many as is physically possible.
