How Many Watts? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 01:19 PM   #31
Originally Posted by sparks1up
This is not a DIY project here! You need an engineer to do load calcs and panel schedules etc. You can't do that yourself and you wont get a permit without them for a commercial job. Electrical contractors are not even allowed to design 3-phase systems, even if we know how! You have too many conflicting things in your assessment of loads and voltages. While there are many here that are happy to help in the end you're going to have to get an engineer to do the calculations!
And btw, a 200-amp rated panel does not mean the panel is fed with 200-amps and even if it was you are still limited to 80% of that leaving you 160-amps. An engineer will look at not only the panel and loads but also the equipment feeding this panel. It is not uncommon to see a 200-amp rated panel or even a 225-amp rated panel fed with a 100 or 125-amp service.
Again, you need an engineer!
Good info. Thanks. I have an appointment with an engineer and electrician. At least I have some fundamentals.
Karlos72 is offline   Reply With Quote
How to Increase the Watts in my Solar Panel? rdlrn19 Green Home Improvement 1 03-02-2010 06:55 PM
Watts Vacuum Breaker goochman Plumbing 2 06-28-2009 02:32 PM
Watts up with HD's product line? Ultrarunner2017 Plumbing 2 03-25-2009 10:10 PM
Watts vs. Volt-Amp Billing? Max P Electrical 19 07-24-2007 07:05 AM
Watts to Amp Rze Electrical 2 08-10-2006 12:57 PM
