How Many Volts, Amps, Watts? Does It Take To Start A Fire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 04:29 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
How many volts, amps, watts? does it take to start a fire?
I setup a custom notification system for mouse traps and there is electricity running through them and when the circuit is broken, it triggers the notice.
The voltage is 5vdc and not sure of the current but it's very low. I'm just wondering, could a setup like that have any potential to start a fire? I can't see how, but I rather be safe than sorry. What does it really take for electricity to start a fire? I would imagine it takes quite a decent spark?
Old 10-26-2012, 04:36 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,600
At only 5v there could only be the tinest of spark, if at all !
So if there is nothing combustable really close you should be ok !
At 5v it sounds like a logic level,
so if so the currents involved would be quite low.
dmxtothemax is offline   Reply With Quote
Old 10-26-2012, 04:50 PM   #3
Wire Chewer
Rewards Points: 138
Yeah it's logic level, it's going to an arduino board. There is also no path to ground available as it's just a return back to the board, so no way of it shorting out. The psu does have potention for quite a few amps though, it's a computer power supply. Should I look at fusing it perhaps? Not sure where I'd buy a fuse/fuse holder though. Could probably get away with like a 50ma fuse.
Old 10-26-2012, 05:20 PM   #4
Rewards Points: 826
Put a 1000 ohm resistor in series with +5vdc at the source to limit current to 5mA
curiousB is offline   Reply With Quote
Old 10-26-2012, 06:02 PM   #5
Wire Chewer
Rewards Points: 138
Hmm yeah that should work never thought of that, I have a box with a few resistors in it think there may be a 1k or close one in there.
Old 10-26-2012, 06:26 PM   #6
Rewards Points: 14,294
Red you sure must have a lot of free time on your hands to come up with this stuff.
Missouri Bound (10-26-2012)
Old 10-26-2012, 07:18 PM   #7
Missouri Bound's Avatar
The smell of a trap gone unnoticed it usually enough notification...
Do you want it your way or the right way?
Old 10-26-2012, 07:23 PM   #8
Wire Chewer
Rewards Points: 138
It actual saves me time considering I have to vacuum the whole room every time I open the attic hatch to check manually.
Mice flash frozen at -30 surprisingly do not smell like anything. That seems to be when I get them the most. Though I've already caught like 5 so far and there's not even any snow on the ground yet. It's late again this year.
Old 10-26-2012, 07:49 PM   #9
Rewards Points: 3,256
So you also have a CO2 extinguisher that gives a shot when a trap is tripped.
zappa is offline   Reply With Quote
Old 10-26-2012, 07:53 PM   #10
joed's Avatar
Rewards Points: 13,696
Put a fuse in line instead of a resistor. 5VDC with enough current behind it could most certainly start a fire.
Old 10-26-2012, 08:44 PM   #11
Wire Chewer
Rewards Points: 138
That could work too, but when it's -30 and an animal that size dies it does not take long for it to freeze.
Actually I just dispose of them in the trash, I only noticed a smell when I had 4 of em in there, then I changed out the trash, but it could have also been the onions that were rotting. Mice seem to just dry up.
And I'll go with the fuse idea then if that's better. Where would I find such low amperage fuse? I'm probably worrying for nothing considering some people have illegal live 120vac wires in their walls at times without proper junction box and don't get a fire, but I rather play it safe.
Old 10-26-2012, 09:49 PM   #12
joed's Avatar
Any one of these options will work. Napa, pep boys, or car audio installers should have have them. Google 'inline fuse' to find online.
Old 10-26-2012, 11:45 PM   #13
Seem like you need to find a way to keep the critters out rather than killing them when they get in. Mice will always go to where the food is...what do you keep in your attic?
Old 10-27-2012, 02:24 AM   #14
Wire Chewer
Rewards Points: 138
Yeah working on trying to figure out how they're getting in. This is a temp solution, and once I do figure out, it will stay up there regardless just in case. I actually hate having to kill animals but these guys can also burn my house down if they really want to. Something about that tasty copper center those big chewy wires have.
At this point I'm just blindly blocking any random hole I can find around the house. There's a few where I think they may had been coming in through, assuming there's an opening inside the wall in the attic space.
Old 10-27-2012, 03:39 AM   #15
I hate mice and I'm always fighting them in my trailer and equipment. Last weekend one built a nest so deep inside of my central heater that I had to bring it home and disassemble it to get everything out.
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 06:48 PM
Cold weather is here, looks like time to start a fire Scuba_Dave Off Topic 78 10-03-2010 10:21 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 07:59 PM
