How Many Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 01:44 AM   #1
How many switches?
I have an attached garage that is entered through my sun porch where my switches are. I was wondering if my two single pole switches: (one to operate garage lights, and one for the outside garage lights) is sufficient. Or do I also need switches on the opposite side, where the garage door is, to operate these lights?
ajg767 is offline   Reply With Quote
Old 03-18-2012, 01:58 AM   #2
Depends on you. Personal preference.
jammin06 is offline   Reply With Quote
Old 03-18-2012, 07:53 AM   #3
Rewards Points: 2,494
What do you mean by the word "need" as in "Or do I also need switches on the opposite side"
When you say garage door do you mean the vehicle door or a pedestrian door?
I believe code...210.70A2b says:
at least one wall switch-controlled lighting outlet must be installed to provide illumination on the exterior side of outdoor entrances or exits with grade-level access
at least one wall switch-controlled lighting outlet is required for attached garages.
If you want additional switches on the opposite side and you want to control the existing lights you will need 3-way switches.
hammerlane is offline   Reply With Quote
Old 03-18-2012, 11:43 AM   #4
Rewards Points: 58
Since you have an existing setup, no additions to the wiring or lighting circuits are required. You not required to bring something up to code, if it exists presently. Naturally unsafe or faulty wiring should be addressed. Your situation is one where nothing needs to be done unless you want to do it.
However. It seems silly to have to enter your garage through your porch each time to turn on the lights. I would use a three way set up so that you can turn on at least some lights from both locations. This is not hard to do and is explained on this forum many times over. Use the search function above and use the keywords "three way switch", or "switches". Check it out and see if you want to address it or not. It is up to you. I would do it just for the convenience.
Old 03-18-2012, 11:56 AM   #5
Old 03-19-2012, 06:16 AM   #6
Thanks for every ones help.
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 01:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
Replacing multi-use light switches jimclark Electrical 4 08-30-2011 03:05 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
