How Many Stoves On 200 Amps? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 04:50 PM   #1
How many stoves on 200 amps?
Hi there,
I have 200 amp service to a rental property with 3 units. Service is split at separate meters and then to separate panels. Based on the rating of the mains on the breaker boxes, each unit gets 60amps (actually, one says 100A, but the disconnect switch leading to it only has 60amp cartridge fuses in it).
Three units means we have three kitchens, each with a standard full-size electrical stove (40A double breaker). I want to make sure that if all tenants are using the range/oven and otherwise normal electrical load (lights, tv, etc) there won't be a problem with the available power...
I don't really understand amps...to me if everyone were running their oven and a few other items, we'd potentially exceed capacity. At the same time, houses used to be 60amps and might have had more total demand on that service than I do since this house has been split up electrically.
I am renovating, and could put in a gas stove in unit 3 to reduce electrical demand, but since itís a rental unit, I donít want to spend the ~$800 for the quoted job or the extra money on the gas stove. But itís an option Iím considering. Does anyone think I need to do this? I donít want the breakers constantly going when people come home and cook dinner ;-)
here's a quick breakdown of what each unit contains...i can provide a more detailed list if required, but i'm not at home right now...
Unit 1:
1 oven/range
~5 or 6 15A circuits of a combination of lights/outlets
~500w baseboard heater on 20A circuit
Unit 2:
1 oven/range
1 Dishwasher
2x 20Amp counter outlets
1 500w baseboard heater on 20Amp
Unit 3:
1 oven/range
1 dishwasher
1 washer/dryer
2x 20amp counter outlets
1000w under-tile heater on 20A circuit
~8 or 9 circuits of a combination lights/outlets (15A)
Forced air furnace (but itís Gas heat, gas water tank too)
Thanks for your help! Note that upgrading service to 300A is not an option at this time.
J
juice2000 is offline   Reply With Quote
Old 01-02-2009, 05:05 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Unit 3 has washer and dryer gas heat and water heater. What do 1 & 2 heat heat with and does 1 & 2 have a washer and dryer? What's the total square footage?
wirenut1110 is offline   Reply With Quote
Old 01-02-2009, 05:12 PM   #3
Electrician
Rewards Points: 760
Is this in an exisitng building that you are renovating. If so how long has it run with this setup. If your not haveing any nusience tripping or not adding any big items I would not worry about it.
Lets say everyone is useing there stove at full tilt(very unlikely because ovens cycle on and off) and they are all pulling 40A(very doubtful). That is only 120A leaving you 80A of power for your light and plugs which is more then enough.
If you are worried about it I would either get an electrcian or find a load calculation online and do a demand load. They are based on the square footage of the unit and the items going into it.
darren is offline   Reply With Quote
Old 01-02-2009, 05:31 PM   #4
sorry, i should have been more clear. there's only 1 furnace/water tank for the house, so it supplies to all the units. however, it is wired to unit 3. neither other unit has a washer or dryer. there is no central air conditioning in any of the units.
unit 1 and 2 are both approximately 500 square feet ( 1br apt., each using 1 level of a ~2000 square foot home)
unit 3 is approximately 900-1000 square ft (2 levels of the house)
Old 01-02-2009, 05:35 PM   #5
Idiot Emeritus
Rewards Points: 1,492
The chance of all 12 burners and all 3 ovens being on at the same time is VERY small.
Even if they were, you'd still be OK.
I didn't do an actual load calc, but unit 1 and 2 are likely OK with 60 amps each, unit 3 is a bit of a push though. If unit 3 could be upgraded to 100 amps it'd be a bit better.
I think this installation will survive just fine as it is.
Rob
micromind is offline   Reply With Quote
Old 01-02-2009, 05:43 PM   #6
If you are worried about it I would either get an electrician or find a load calculation online and do a demand load. They are based on the square footage of the unit and the items going into it.
It is an existing structure, but since we gutted the house in renos, it is not operational right now and we haven't tested it since updating (got rid of the old stoves as they were nasty and don't have replacements yet). We bought the place with tenants. There were actually 4 stoves at the time, but only 3 would have been used, and 2 were the smaller variety stoves, so lower wattage i'm guessing. Tenants never mentioned anything about tripping breakers, and there was only 100A at the time service (but no washer/dryer/dishwashers).
We upgraded it to 200A--looking back we probably should have gone to 300A and 100A per unit, but were told 200A would be enough. I'm just trying to make sure it will be. If any one unit's stove is drawing its max 40A, there's only 20A left over for everyting else in the unit. Since all the walls are open right now, it is easy to put in the gas line, but expensive.
I will look for a load calculator.
J
Old 01-02-2009, 06:04 PM   #7
Rewards Points: 510
I came up with ~164 amps. I may have added a couple small appliance circuits that didn't need to be but it's pretty dang close.
Curious to see what anyone else came up with.
Old 01-02-2009, 06:51 PM   #8
Electrician
Rewards Points: 760
I would not worry about it only being 60A. My house runs off of 75A(natural gas furnace and HWT) and i have never tripped the mains.
Wiring a compressor scrapin Electrical 25 03-19-2012 12:35 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
