How Many Runs Through A Stud Hole? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 04:37 PM   #1
Rewards Points: 204
How many runs through a stud hole?
How many cable runs can you run through a stud/joist hole? I have two and I want to run one more and wondered if it was against code.
Abs777 is offline   Reply With Quote
Old 04-22-2010, 04:52 PM   #2
Rewards Points: 204
No problem. Pull it through. Don't forget the nail plates!
Old 04-22-2010, 06:14 PM   #3
Knows everything but that
Rewards Points: 150
What are the regulations regarding nail plates? How many do I need and where? Also, can you use the plastic ones that are held in by nails or must they be the giant staple like nail plates? Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 04-22-2010, 06:26 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Plastic will do you no good.
If the wire is closer to the edge of the stud than 1 1/4" it needs a nail plate.
jbfan is online now   Reply With Quote
Old 04-22-2010, 06:29 PM   #5
Master Electrician
Rewards Points: 3,920
Shane
nail plates and staples are not the same thing.
brric is online now   Reply With Quote
Old 04-22-2010, 06:50 PM   #6
Nail plate
Usually one plate on the wall to cover teh area of the hole
If an interior wall & both sides open I'd put a plate on each side
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
Driving a hole into a stud handy man88 Carpentry 2 06-08-2008 09:28 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
