How Many Recessed Light Cans (75W) Per 15AMP Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 10:58 AM   #1
DIY
Rewards Points: 39
How many recessed light cans (75W) per 15AMP Circuit?
I'm doing some new recessed lighting in bedrooms and am trying to gauge how many should be put on each circuit?
I understand that the good old law of 80% of maximum load capacity lands around 1440 watts on a 15 amp circuit. I'm installing IC cans that are rated up to a 75W bulb max each. I'll probably use an efficient bulb using less wattage but I know installation should be for the max amount per fixture.
So assuming fixtures are rated up to 75W each, does that in theory mean that 1440Watts divided by 75Watt fixtures = 19.2 possible fixtures per 15AMP circuit on a 14Gauge line? That sounds like way too many. I was always told that recessed lights should be kept to a max of around 8+/- max.
Can someone chime in and give what is possible in this scenario (NEC Guides), and also what they recommend as a max amount of fixtures in their own installs?
RocketManZ is offline   Reply With Quote
Old 10-21-2011, 11:07 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Your max amount is just that, whatever your maximum allowable wattage is divided by 75. You can have that many lights or one or any number in between. Now any average sized bedroom should be able to be served by 4-6 lights but it depends on the layout.
iminaquagmire is offline   Reply With Quote
Old 10-21-2011, 11:12 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Check local code for this and you're other question.
Some areas allow 10 outlets per circuit, and consider each light as an outlet.
Old 10-21-2011, 11:15 AM   #4
DIY
Rewards Points: 39
Thanks for the info. So I guess that 19.2 number is right theoretically, it just sounds so high. I'm expecting between 4-6 per bedroom, so that is on average about 12-16 75W max fixtures. So i'm guessing 2 circuits will be ideal.
Old 10-21-2011, 12:05 PM   #5
Code05's Avatar
Rewards Points: 1,104
When did residential lights become a continuous load?
220.19(A)(1) and 220.20(A).
75%????? Where did this come from???
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
gregzoll (10-21-2011), Speedy Petey (10-24-2011)
Old 10-21-2011, 12:06 PM   #6
Code05's Avatar
Code reference please.
Old 10-21-2011, 12:16 PM   #7
Licensed electrician
Rewards Points: 1,490
Perhaps what was meant was the circuit ampacity/maximum bulb per fixture rating. In this case 75 watts.
Old 10-21-2011, 12:35 PM   #8
Code05's Avatar
Did not think about that. Thanks. I thought it was a buffer on the "80%" rule so commonly misapplied.
Old 10-21-2011, 04:27 PM   #9
Rewards Points: 338
Yes, that's what I meant. Forgot about the number of outlets maximum. They don't have any amendments like that here. Best to check with your local building department to make sure if this is a permitted job.
Old 10-21-2011, 06:13 PM   #10
Master Electrician
Rewards Points: 3,820
You may want to consider how many fixtures are installed per switch as the standard dimmers we use have a 600 watt limit. That would be a max of 8 @ 75 watts.
brric is online now   Reply With Quote
Old 10-23-2011, 10:42 PM   #11
DIY
Rewards Points: 39
Checking locally, and I just looked in my box again and I have the room to fix a few more breakers so I'm going to put max 8-75W fixtures on each line, with 4 in each room on their own switch.
Old 10-23-2011, 11:11 PM   #12
liscenced electrician
Rewards Points: 538
Your 19 can lights doesn't sound off to me. Especially since most people put cfl bulbs in with a wattage around 20 watts. 19 doesn't sound too high to me at all. Just don't forget to take your other loads in to consideration. Ceiling fans, closet lights etc.
jimmy21 is offline   Reply With Quote
Circuit for bathroom in the basement felipe_heidrich Electrical 4 08-26-2011 04:54 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 08:26 AM
