How Many Receptacles On A 20amp Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 11:22 PM   #16
kevinp22's Avatar
Rewards Points: 252
Originally Posted by gfink View Post
In one of our bathrooms, the GFI is in the laundry room that feeds the bathroom. It is a 15amp circuit. In another bathroom, the GFI is in the garage, also a 15 amp circuit. Is it different for 20 amp circuits?
no, it is not differemt. this doesnt meet current code. may or may not have been okay at thetime of installation.
kevinp22 is offline   Reply With Quote
Old 05-19-2012, 08:07 AM   #17
Thanks Kevin. We have 4 bathrooms and 3 are done this way - must have been code in 95-96. In another house I owned, built in 2003, the outlets are on the same circuit for all bathrooms. Lights and fans are seperate circuits but are shared with outlets and lights in adjentcent bedrooms. That's way I asked if I could have outlets from an adjentcent room shared with the outlets in just one bath. I have used "pros" for many projects over the years. Sometimes their work is good but too many times it is not. Whether I hire a pro or not - I still like to know the correct way so I can challenge the "pro" to do it right. I'm a DYI at heart.
gfink is offline   Reply With Quote
The Following User Says Thank You to gfink For This Useful Post:
kevinp22 (05-19-2012)
Old 05-19-2012, 08:15 AM   #18
Originally Posted by gregzoll View Post
Florida is not a country of its own. Your answer to how many receptacles on a 20 amp. As many as you want. If you want a hundred, you can put that many on there. The real question that you should be asking, is what is the maximum amount of wattage that you can load a circuit, not how many receptacles.
Gee, thanks for the tip on Florida - I didn't know that . I aready know the answer on the wattage so that is way I didn't ask.... Funny, I thought this was a DIY forum to share help, knowledge and experiences
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Recessed Lighting - How many per 20amp circuit dcd22 Electrical 10 08-27-2007 05:36 PM
